12-21-2008, 11:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | format chinese samsung 629+ failed chinese samsung 629+ still restart with sim after format( rx:4, tx:5, L10c cable )... cause failed ... her's a log : COM8 [VCP0] selected module v2.72 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001C03:0001 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: RATECH25_GEMINI_PCB01_GPRS_MT6225_S00.T588_TY_ML_A _1_0T02S0704.BIN ver. sw 2: T588_TY_ML_A_1_0T02S0704, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[RATECH25_GEMINI_PCB01_GPRS_MT6225_S00.T588_TY_ML_A _1_0T02S0704.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[RATECH25_GEMINI_PCB01_GPRS_MT6225_S00.T588_TY_ML_A _1_0T02S0704.BIN]_20081221-113056.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 122 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Last edited by noure30; 12-21-2008 at 11:51. |
12-21-2008, 13:13 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Did you tried to make 112/emergency call without sim card ? What is the results ? |
12-21-2008, 14:55 | #4 (permalink) |
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | it seems the phone with differents IMEI ( *#06# ) IMEI : 356102030481071 imeisv:78 imei:135790246811220 how to make repair imei ... thanks for help ... |
12-21-2008, 16:01 | #5 (permalink) | |
In most cases this means that phone hardware is damaged. You must check phone hardware, f.e. replace PA. Imei: you have "Write" button in software "Service" page, but you need to check hardware first. | |
is possible to format chinese phone only with usb cable? | rerasta | Chinese Models & Cloned Phones | 17 | 06-19-2009 21:11 |
how to format chinese PDA HT508 | mansi | Infinity-Box | 12 | 05-17-2008 19:55 |
Samsung 629 | LEOCALA | Phone Unlocking Codes & Maps | 0 | 04-28-2008 23:05 |
Format Chinese Phones Using Data Cable? | borndevils81 | Chinese Models & Cloned Phones | 0 | 11-20-2007 19:43 |
Help to Format Chinese Mobiles - anycool d66 | .:: Sepid Gsm ::. | Chinese Models & Cloned Phones | 2 | 10-31-2007 20:36 |
