06-30-2011, 19:04
#3 (permalink)
Join Date: Sep 2006 Location: (¯Catch Me If U Can¯) Age: 50
Member: 360073
Thanks Meter: 2,181 | Quote:
COM4 [VCP0] selected
module v3.94
Device: _Autodetect MT6205-6239 NOR
Checking data, wait...
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 353923300620115
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:5BB0:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22212201:42EA0000000000
flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 420000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
New firmware found (v.3.94, database date: 20.06.2011):
H659DX_QCIF_NT_ML_PCB01_GPRS_MT6223P_S00.H659DX_QC IF_NT_ML_V1_0_3.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 04
sw version: H659DX_QCIF_NT_ML_PCB01_GPRS_MT6223P_S00.H659DX_QC IF_NT_ML_V1_0_3.BIN
project-id: H659DX_QCIF_NT_ML_V1.0.3, 00000000
code offset: 00000000
ffs offset/size [01]: 00DC0000/00240000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00DC0000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00DC0000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00240000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00DC0000-00FFFFFF
firmware area: 00000000-00DBFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
detecting ffs/eeprom structure pass 2...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 13579024681122
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 54 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
| imei write channel: imei #1 (default imei inside firmware) with module v3.94 (work perfact) |
