12-31-2009, 09:51 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: ina 4 sure
Member: 911645 Status: Offline Thanks Meter: 19 | Nexian g922 phonecode i got 1 phone, locked code.. i've been trying to unlock it using infinity and other Chinese sw repairing boxes, but no success. Code: CPU: MT6225 result: Rx:4 Tx:5 here's log when i did 'user/lock code; unlock method: read codes' Code: COM2 [VCP0] selected module v3.04 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:EB03:0008 status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support warning: wrong packet cs connection lost error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! Code: COM2 [VCP0] selected module v3.04 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:EB03:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 1C007C001C007C:1C007C00000000 flash: Mitsubishi Mitsubishi std [def 0008x004000 00FEx020000 0008x004000] 32Mb detecting chip #01 in region #00... flash: 1C007C001C007C:1C007C00000000 flash: Mitsubishi Mitsubishi std [def 0008x004000 00FEx020000 0008x004000] 32Mb number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 1C007C001C007C:1C007C00000000 flash: Mitsubishi Mitsubishi std [def 0008x004000 00FEx020000 0008x004000] 32Mb detecting chip #01 in region #00... flash: 1C007C001C007C:1C007C00000000 flash: Mitsubishi Mitsubishi std [def 0008x004000 00FEx020000 0008x004000] 32Mb it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.04, database date: 24.12.2009): TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1.BIN project-id: E502-3B.MP.RS.ID.TELKOMSEL.V1, 00000000 code offset: 00000000 ffs offset/size [01]: 01000000/00FE0000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01000000 standard ffs/eeprom offset confirmed: 01000000 detecting ffs/eeprom size... ffs/eeprom size: 01000000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01000000-01FFFFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent detecting ffs/eeprom structure pass 1... ....................................... detect standard ffs/eeprom location pass #1... ................................................................ detect extended ffs/eeprom location pass #1... ............ detect standard ffs/eeprom offset pass #1... detect standard ffs/eeprom location pass #2... ................................................. detect standard ffs/eeprom offset pass #2... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__ffs_20091231-142631.B0E.bin flash: 1C007C001C007C:1C007C00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 1C007C001C007C:1C007C00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 64 min 56 sec Remove/Install battery now ! when standard codes entered (1122,2233 1234,0000), it won't open i tried also using other methods, but no luck.. tried also to do format ffs:safe mode, here's log Code: COM2 [VCP0] selected module v3.04 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:EB03:0008 status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support warning: wrong packet cs connection lost error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! Code: COM2 [VCP0] selected module v3.04 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:EB03:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 1C007C001C007C:1C007C00000000 flash: Mitsubishi Mitsubishi std [def 0008x004000 00FEx020000 0008x004000] 32Mb detecting chip #01 in region #00... flash: 1C007C001C007C:1C007C00000000 flash: Mitsubishi Mitsubishi std [def 0008x004000 00FEx020000 0008x004000] 32Mb number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 1C007C001C007C:1C007C00000000 flash: Mitsubishi Mitsubishi std [def 0008x004000 00FEx020000 0008x004000] 32Mb detecting chip #01 in region #00... flash: 1C007C001C007C:1C007C00000000 flash: Mitsubishi Mitsubishi std [def 0008x004000 00FEx020000 0008x004000] 32Mb it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.04, database date: 24.12.2009): TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1.BIN project-id: E502-3B.MP.RS.ID.TELKOMSEL.V1, 00000000 code offset: 00000000 ffs offset/size [01]: 01000000/00FE0000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01000000 standard ffs/eeprom offset confirmed: 01000000 detecting ffs/eeprom size... ffs/eeprom size: 01000000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01000000-01FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__ffs_20091231-164226.B0E.bin flash: 1C007C001C007C:1C007C00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 1C007C001C007C:1C007C00000000 Finalization Done Finished, time used: 34 min 22 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! tried to flash using another normal phone back-up file, it is still locked what should i do? |
12-31-2009, 18:51 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! can you upload backup from this phone, i will check if EEPROM erea is detected correctly and please do not use speed 115200, this will take years to read out 32mb backup www.rapidshare.com |
01-04-2010, 05:38 | #4 (permalink) |
Member: 911645 Status: Offline Thanks Meter: 19 | here's ffs back-up http://rapidshare.com/files/33002109...6.B0E.bin.html if u need fullflash back-up, i'll also upload, thank u |
01-07-2010, 21:24 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try to flash with this file: flashfiles/Micromax/Q3/Micromax-Q3_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3A_MP_RS_ID_INDIA_V0_2_En.B0M.bin |
01-08-2010, 12:56 | #9 (permalink) |
Member: 911645 Status: Offline Thanks Meter: 19 | TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_RS_ID_TELKOMSEL_V1__fullflash_20091229-194553.B0 (22.562kb) TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3A_MP_RS_ID_INDIA_V0_2_En.B0M.bin (10.590kb) there's big difference on size, should it be ok? I've tried to flash phone w/ another g922 normal back-up (bin file) n convert it using langPackEditor that CM may recognized n flashed it, but phone is still locked, like nothing happened.. just worried if anything wrong happened (phone dead) and i couldn't restore phone back to its original conditions to customer (locked phone) |
01-19-2010, 09:49 | #12 (permalink) |
Insane Poster Join Date: Jan 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 441483 Status: Offline Thanks Meter: 6 | COM3 [VCP0] selected module v3.03 Device: Nexian-NX-G922 Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9C03:0009 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00040000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.03, database date: 16.01.2010): TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_NU_ID_TELKOMSEL_V3.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_NU_ID_TELKOMSEL_V3.BIN project-id: E502-3B.MP.NU.ID.TELKOMSEL.V3, 00000000 code offset: 00040000 ffs offset/size [01]: 01000000/00FC0000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01000000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Nexian-NX-G922_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_NU_ID_TELKOMSEL_V3__ffs... file saved: C:\Program Files\InfinityBox\MModule\Nexian-NX-G922_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-3B_MP_NU_ID_TELKOMSEL_V3__ffs_20100119-162002.B0E.bin flash: 89890100040089:89890100000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 89890100040089:89890100000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 34 min 44 sec Remove/Install battery now ! |
spiderman cannot detect ic flash nexian g922.. please release the new update.... | G_TRON84 | SpiderMan | 7 | 05-08-2010 17:40 |
Flash nexian g922, flash device not supported | fcs | SpiderMan | 3 | 04-28-2010 16:20 |
help mt6225 nexian G922 | birugitu | Mastertools | 3 | 03-27-2010 18:39 |
Lock Code Nexian G922 | vampire13 | CPF-BOX Ⅱ | 33 | 02-11-2010 15:00 |
LG 8210 G922 FLAHS Chinese system | xiangyinbo52002 | LG | 0 | 07-27-2006 11:50 |
