Old 03-18-2010, 12:39   #1 (permalink)
somonahmed's Avatar
Member: 465069
Sonork: 100.1661026
Thanks Meter: 190
Red face format ok but no power on but what is this problem ?
kxssetel-x8 model
rom info ver: 07
sw version: M658_P2_XKSS_L71_PCB01_GPRS_MT6225_S00.M658-XKSS-P2-ST4-L71-100107.BIN
project-id: M658-XKSS-P2-ST4-L71-100107, 00000000
code offset: 00020000
ffs offset/size [01]: 00E00000/00200000
rom info structure: 2nd [standard] generation
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
flash: 2088C4FFFF0013:2088C400000000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
security area (sec info, part #1) size is incorrect: FFFFFFFF
security area (sec info, part #2) can not be unpacked
product id: ?
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
what is area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
Old 03-19-2010, 20:06   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
can you show full log, from beginning?
SE w395 i want to unlock.....what is this problem? adamsquall Universalbox 2 03-29-2010 14:11
n90 flash ok ui setting ok but no power on raknahs Nokia Hardware & Hardware Repair 1 04-07-2008 17:40
3230 flash is ok but no power on hasanphone Nokia Hardware & Hardware Repair 1 02-02-2008 08:38
gx 25 no charging, no power on but flash ok the sorrow Sharp 4 08-29-2007 21:39
8210 charge OK, Flash OK, but no power on Two-Dogs Nokia Hardware & Hardware Repair 1 01-20-2003 07:46
Page generated in 0.16014 seconds with 9 queries
