04-13-2008, 14:15 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! procedure of formating and restoring IMEI for second MCU is abolutely same as for first MCU. the only difference is that you using second MCU pinout. method 1, 2 is test mode change. method 3 makes IMEI change in flashing mode. you must try all methods 1,2,3. start from 1,2 end with 3 |
04-14-2008, 02:53 | #3 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 59
Member: 185776 Status: Offline Thanks Meter: 73 | U want second cpu formate first u have to get second cpu pin out.The way is use pinfinder,select pin revrese button near left side of SET button,then use find it button,u will get second cpu pin out.Then u can do as usual formate, write, imei for second cpu. |
second cpu imei change | hatekgsm | SpiderMan | 6 | 11-20-2008 14:04 |
how to speadtrum cpu pinfinder and 1. and 2. cpu imei writer | turkcellgsm | VE-KING | 2 | 08-02-2008 08:59 |
n72 second cpu imei can't write | BATTAL | Infinity-Box | 2 | 07-31-2008 10:31 |
how to find the pinout of first and second cpu of dual cpu phones | maximas007 | Infinity-Box | 3 | 03-20-2008 05:38 |
Bugs 2.32 Not write imei n72 6205 second cpu!!! | volkangsm2 | Infinity-Box | 1 | 03-14-2008 22:28 |
