01-22-2008, 08:26 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Formating FFS for 8030 Type RH-13 I recieved one Chinese Fone 8030 RH-13 when i try to Read Detail Information i get the following Message(Picture is attached for Reference) and here i also attach system backup of the fone , when i try to power on fone normally it doesn't power on but when i press format FFS then fone power on but doesn't connect with the software. ==== log opened: [22-01-08 10:07:30 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.22 S/N: ********* Wait... Device: Autodetect 6205-6227 NOR Done COM7 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:C2C1:8DA2 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.31F4F327.[E550_Y1VIRUARFR_E550_GPRS_MT6226_S01.01_1.BIN_A94C 4757].rpl New firmware detected: E550_Y1VIRUARFR_E550_GPRS_MT6226_S01.01_1.BIN - make "Repair security area" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 31F4F327 identification#1 protocol ver: 04 ver. sw1: E550_Y1VIRUARFR_E550_GPRS_MT6226_S01.01_1.BIN ver. sw2: E550_Y1VIRUARFR.01.1 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _31F4F327_E550_Y1VIRUARFR_E550_GPRS_MT6226_S01.01_ 1.BIN_A94C4757_20080122-101225.B0X.bin Finished, time used: 204 sec Remove/Install battery now ! COM7 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:C2C1:8DA2 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 103 sec Remove/Install battery now ! COM7 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair security area Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:C2C1:8DA2 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.31F4F327.[E550_Y1VIRUARFR_E550_GPRS_MT6226_S01.01_1.BIN_A94C 4757].rpl New firmware detected: E550_Y1VIRUARFR_E550_GPRS_MT6226_S01.01_1.BIN - make "Repair security area" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 31F4F327 identification#1 protocol ver: 04 ver. sw1: E550_Y1VIRUARFR_E550_GPRS_MT6226_S01.01_1.BIN ver. sw2: E550_Y1VIRUARFR.01.1 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _31F4F327_E550_Y1VIRUARFR_E550_GPRS_MT6226_S01.01_ 1.BIN_A94C4757_20080122-101653.B0X.bin Finished, time used: 100 sec Remove/Install battery now ! COM7 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:C2C1:8DA2 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 109 sec Remove/Install battery now ! Take Care ENJOY |
Bvlgari bv 8030 b 897 13 chocolate brown gradient rhinestones plastic ********es | IPMART | ipmart WebShop | 0 | 11-06-2008 07:00 |
Bvlgari bv 8030 b 877 13 honey brown gradient rhinestones plastic ********es | IPMART | ipmart WebShop | 0 | 11-06-2008 07:00 |
probleme with format ffs for my way slim | merdjiosse | Infinity-Box | 4 | 07-16-2008 22:16 |
N95 V3 Type Jack Dead-did Format Ffs-still In Dead | zonetrichur | Multi-Box | 4 | 05-15-2008 13:24 |
format FFs for E200!?! | sale | UST Pro II | 1 | 04-20-2008 20:09 |
