Old 10-31-2009, 13:21   #1 (permalink)
Member: 1132412
Thanks Meter: 5
Formating and write flash always failed
COM7 [Serial2] selected
module v2.95
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Do you want to make ffs/eeprom backup before format ?
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:FE03:000D
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC240200000000:18E59F00000000
error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed
flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5217B8C1.[HUSCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O.BIN_CABEE31B].rpl
rom info detection finished
device-id: 5217B8C1
rom info protocol ver: 04
ver. sw 1: HUSCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O.BIN
ver. sw 2: PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O, 1BE3BECA
address offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
ffs formatting...
error: no any expected answer
error: flash erase error: 00E00000
Finalization Fail
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H USCKY7_S60_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O__system_log_ 5217B8C1_CABEE31B_20091031-175147.B0X.bin
Finished, time used: 54 sec
Remove/Install battery now !
wil some help me regarding this? what to do know?
Old 10-31-2009, 13:31   #2 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
module v2.95
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
TCL-ID is absent
device-id: 5217B8C1
ffs/eeprom chip: 00
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Fail
pb can be hardware..? what is phone condition now..?
The Following User Says Thank You to LoveLess For This Useful Post:
Old 11-01-2009, 00:02   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
this is new unsupport flash type.
we are working under this problem
Old 11-03-2009, 05:51   #4 (permalink)
Member: 1132412
Thanks Meter: 5
phone is working but struck in some seconds
thanks
Old 11-03-2009, 20:13   #5 (permalink)
Member: 148515
hello!
working hard under supporting this new flash IC type
Old 11-08-2009, 10:43   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
thanks
Hello,
I was a problem with new type of phone hardware.
Please, try to use this software for flashing: http://www.infinity-box.com/download...acle_v2.97.rar
It was tested with new flash chip types.
Waiting for your results.
The Following User Says Thank You to InfinitySupport For This Useful Post:
F480 flashing always fails James_S UST Pro II 3 01-29-2009 04:45
dead n6235, flash-always failed at the end. tomlat Nokia CDMA 1 11-10-2007 20:17
SmartMoto 2.17 fail in reader and writing flashing ruyramonn Smart-Clip 1 02-14-2007 08:31
VS2 flashing always fails kiwiboi Infinity-Box 1 10-03-2006 09:40
Page generated in 0.20058 seconds with 9 queries
