Old 10-08-2010, 08:12   #1 (permalink)
Member: 583468
Sonork: 100.1592004
Thanks Meter: 106
Forme l300
HELLOO SUPPORTER I GOT A "FORME L300" DEAD NOT POWERING
SO READ THE FLASH FILE AND EPROME
I SEARCH SUPPORT BUT DIDN'T FIND THE FLASH FILE..
SO I MA ATTACHING THE FILE
TELL ME WHAT TO DO...
DO I TAKE RISK AND TRY TO FORMAT IT OR WHAT..
FLASH - D386_PCB01_GPRS_MT6223_S00.SW_V00_05_YIDALONG__ful lflash_20101008-123143.B0M.bin - 4shared.com - online file sharing and storage - download
EEPROM - D386_PCB01_GPRS_MT6223_S00.SW_V00_05_YIDALONG__ffs _20101008-124017.B0E.bin - 4shared.com - online file sharing and storage - download
PLEASE RE PROCESSED IT
Old 10-08-2010, 22:10   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
start from Format FFS complete
Old 10-09-2010, 03:03   #3 (permalink)
Member: 583468
Sonork: 100.1592004
Thanks Meter: 106
hello!
I try to format FFS complete but its says me New Firmware found
see the photo ..in attachment i allredy put the link to the flash file and eeprom ....
and also detected ffs/eeprom address is non-standard : 004E0004
i attach photo in my first post...
here is the log for ffs complete
COM3 [VCP0] selected
module  v3.24
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====>  Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot Off
chip: 0011:645B:000C
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 208810FFFFFFFF:20881000000000
flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
otp offset: 007F0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
====>  Set baud ...
115200
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
New firmware found (v.3.24, database date: 01.10.2010):
D386_PCB01_GPRS_MT6223_S00.SW_V00_05_YIDALONG.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 07
sw version: D386_PCB01_GPRS_MT6223_S00.SW_V00_05_YIDALONG.BIN
project-id: D386.SW.V00.05.YIDALONG, 00000000
code offset: 00000000
ffs offset/size [01]: 00700000/00100000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00700000
checking area [00000000]: 00080000-007FFFFF...
ffs/eeprom found near: 004E0000
Detected ffs/eeprom address is non-standard: 004E0000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 004E0000
detecting ffs/eeprom size...
ffs/eeprom size: 00320000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:004E0000-007FFFFF
firmware area: 00000000-004DFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: D386_PCB01_GPRS_MT6223_S00.SW_V00_05_YIDALONG__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\D386_PCB01_GPRS_MT6223_S00.SW_V00_05_YIDALONG__ffs_20101009-073050.B0E.bin
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 12 min 58 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
but set is not powering on
Old 10-09-2010, 04:18   #4 (permalink)
Member: 608516
Sonork: 100.1607007
Thanks Meter: 123
do complete ffs format and then try other wise i will give u the file
Old 10-09-2010, 07:50   #5 (permalink)
Member: 583468
Sonork: 100.1592004
Thanks Meter: 106
yes i alredy try it ..not powering on ..aft ffs format complit...
tell me wht to do
Old 10-09-2010, 18:34   #6 (permalink)
Member: 148515
hello!
unfortunately, we dont have exactly same flash file,
but as long as this phone already dead- there will be no problem to try following files:
flashfiles/ChineseMiracle/_MT6223/8m/D386_PCB01_GPRS_MT6223_S00.SW_V00_02_YIDALONG__FOR ME-F8_w_eeprom.B0M.bin
flashfiles/ChineseMiracle/_MT6223/8m/D386_PCB01_GPRS_MT6223_S00.SW_V00_03_YIDALONG__For me-N82_8m_En_Hi.B0M.bin
Old 10-10-2010, 04:20   #7 (permalink)
Member: 583468
Sonork: 100.1592004
Thanks Meter: 106
hello!
but u can do one thing na...
i allredy upload the flash and eeprom file ..so can u.....reprocessed it and upload to support area...
that can u do na..
Old 10-10-2010, 05:31   #8 (permalink)
Member: 583468
Sonork: 100.1592004
Thanks Meter: 106
Flash ok but still not pwoering on
COM3 [VCP1] selected
module v3.24
Action: write flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
rom info ver: 07
TCL-ID is absent
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00700000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
standard ffs/eeprom address selected by user
ffs/eeprom size: 00100000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00700000-007FFFFF
firmware area: 00000000-006FFFFF
reading: D386_PCB01_GPRS_MT6223_S00.SW_V00_05_YIDALONG__ffs ...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\D386_PCB01_GPRS_M T6223_S00.SW_V00_05_YIDALONG__ffs_20101010-094358.B0E.bin
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Finished, time used: 16 min 27 sec
Old 10-10-2010, 17:26   #9 (permalink)
Member: 148515
that can u do na..
hello!
your phone firmware is damaged, we can not upload such firmware to support.
try both flash files adviced by me
Old 10-11-2010, 05:49   #10 (permalink)
Member: 583468
Sonork: 100.1592004
Thanks Meter: 106
hello!
sorry bose but the coustmer take the phone back....
Any soft form new Ericsson T65 ? Kilowat Main Sales Section 0 01-19-2002 13:32
want to lock 3310 v503 to orig form eureka8888 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-10-2001 15:53
Form post into the NET.. for member's or helper's Oh_Flip GSM Programming & Reverse Engineering 0 05-28-2001 11:18
Anyone in here form Australia. (Info on 3210 needed) diatribe2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-22-2000 13:19
Page generated in 0.24032 seconds with 11 queries
