08-11-2016, 03:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | >>>FOXPHONE M6 correct the REAL imeis after Flash<<< Write corrects imeis. After flash whit .BIN lost the REAL imeis. Only CM2 correct whit REPAIR PERMANET MODE ((I try whit other two tools but I did not correct)) PROCESS Code: Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930516360D46351AF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930516360D46351AF [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x422EC588B3EECAAA09A1734F157BA6D1 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 861622010000056 IMEI [01] : 861622010000056 IMEI [02] : 861622010000056 IMEI [03] : 861622010000056 Set IMEI [00] : 35521xxxxx0413x3 Set IMEI [01] : 35521xxxxxx413x1 Prepare finished. Security check required! Wait for phone... Phone found! [ 15 ] Sync... Repair done! Perfect!!!! >>MaO<< |
08-11-2016, 03:22 | #2 (permalink) |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | FOXPHONE M6 Write corrects imeis. After flash whit .BIN lost the REAL imeis. Only CM2 correct whit REPAIR PERMANET MODE ((I try whit other two tools but I did not correct)) PROCESS Code: Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930516360D46351AF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930516360D46351AF [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x422EC588B3EECAAA09A1734F157BA6D1 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 861622010000056 IMEI [01] : 861622010000056 IMEI [02] : 861622010000056 IMEI [03] : 861622010000056 Set IMEI [00] : 35521xxxxx0413x3 Set IMEI [01] : 35521xxxxxx413x1 Prepare finished. Security check required! Wait for phone... Phone found! [ 15 ] Sync... Repair done! Perfect!!!! |
08-11-2016, 03:22 | #3 (permalink) |
08-11-2016, 03:44 | #4 (permalink) |
