05-08-2018, 15:44 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india
Member: 1140831 Status: Offline Sonork: no Thanks Meter: 232 | frp error yuho h2 plz help (USBDL : Error init HSUSB!!!) 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065324741441007055D4516D9 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A484147326505071044D916B25D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x73CC19F24381292FB53EC5994FB303E9 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Error init HSUSB!!! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! no info reed Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065324741441007055D4516D9 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A484147326505071044D916B25D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x73CC19F24381292FB53EC5994FB303E9 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Fatal error, buffer empty! Phone connection lost??? Fatal error, buffer empty! Phone connection lost??? Fatal error, buffer empty! Phone connection lost??? Fatal error, buffer empty! Phone connection lost??? Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
05-09-2018, 06:28 | #3 (permalink) |
Member: 1140831 Status: Offline Sonork: no Thanks Meter: 232 | Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! INFO : max-download-size: 0x8000000 INFO : partition-size:flashinfo: 1000000 INFO : partition-type:flashinfo: raw data INFO : partition-size:userdata: 32000000 INFO : partition-type:userdata: ext4 INFO : partition-size:cache: 19000000 INFO : partition-type:cache: ext4 INFO : partition-size:system: 100000000 INFO : partition-type:system: ext4 INFO : partition-size:metadata: 2480000 INFO : partition-type:metadata: raw data INFO : partition-size:nvdata: 2000000 INFO : partition-type:nvdata: ext4 INFO : partition-size:frp: 100000 INFO : partition-type:frp: raw data INFO : partition-size:tee2: 500000 INFO : partition-type:tee2: raw data INFO : partition-size:tee1: 500000 INFO : partition-type:tee1: raw data INFO : partition-size:keystore: 800000 INFO : partition-type:keystore: raw data INFO : partition-size:secro: 600000 INFO : partition-type:secro: raw data INFO : partition-sizeemkeystore: 200000 INFO : partition-typeemkeystore: raw data INFO : partition-size:seccfg: 80000 INFO : partition-type:seccfg: raw data INFO : partition-size:expdb: a00000 INFO : partition-type:expdb: raw data INFO : partition-size:logo: 800000 INFO : partition-type:logo: raw data INFO : partition-size:recovery: 1000000 INFO : partition-type:recovery: raw data INFO : partition-size:boot: 1000000 INFO : partition-type:boot: raw data INFO : partition-sizeara: 80000 INFO : partition-typeara: raw data INFO : partition-size:lk: 100000 INFO : partition-type:lk: raw data INFO : partition-sizerotect2: a00000 INFO : partition-typerotect2: ext4 INFO : partition-sizerotect1: a00000 INFO : partition-typerotect1: ext4 INFO : partition-size:nvram: 500000 INFO : partition-type:nvram: raw data INFO : partition-sizeroinfo: 300000 INFO : partition-typeroinfo: raw data INFO : partition-sizereloader: 40000 INFO : partition-typereloader: raw data INFO : off-mode-charge: 1 INFO : warranty: yes INFO : unlocked: no INFO : secure: yes INFO : kernel: lk INFO : product: S103 INFO : version-preloader: 0.1.00 INFO : version: 0.5 INFO : Done!! OEM : FAILunknown command |
05-09-2018, 06:32 | #4 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
make sure battery power enough and check high speed drivers installed or not | |
