Old 09-01-2018, 09:57   #1 (permalink)
Member: 2325887
Thanks Meter: 134
Thumbs up frp remove error how to connect?
Card found : 69F34682 , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.10
Emergency driver NOT found, make sure it installed!
Download and install from support area following file :
>> InfinityBox_Update_CM2QLM_Drivers_v1.xx.rar
Install it, go to /CM2QLM/Drivers/ and install ALL packages inside
>> If device detected by PC, but not detected by SW :
> 1. Open device manager, find in PORTS section "9008" device
> 2. Change (update) driver to Emergency (or) QHSUSB_BULK
Operation : Reset Settings [ v1.10 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device not found!
Check cable, connection and drivers!
Reconnect Power/Cable!
Wait for phone...
Device not found!
Wait for phone...
Device not found!
Connect device in fastboot mode ...
Device not found!
Wait for phone...
Device not found!
Old 09-01-2018, 10:07   #2 (permalink)
Member: 2325887
Thanks Meter: 134
model is huawei y7 prime
thankssssssssssss
Old 09-02-2018, 04:09   #3 (permalink)
Member: 2601900
Thanks Meter: 519
there is this guy called google.com try to ask him
Old 09-02-2018, 08:10   #4 (permalink)
Member: 2325887
Thanks Meter: 134
how to direct remove??????????//????????????????????
Old 09-02-2018, 09:16   #5 (permalink)
Member: 1882912
Sonork: 100.1677703
Thanks Meter: 263
always use last version ([QLM] v 1.16)
huawei y7 prime not supported yet
Page generated in 0.12270 seconds with 8 queries
