frp romve error k88 zte cm2 [ v1.14 ] Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 0125B725 ID_BLOCK_I : 009720E1 ID_BLOCK_E : 00040000 ID_BLOCK_L : 3CA0EF2EDAAC1EF8C13B98DB86A539AC ID_BLOCK_L : 9172769AC33D8DAAF934593A84D06928 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
you found any other solutioN ?>?> |
y not use the latest ver.? you have old ver. so maybe it is not supported during that time |
i have problem in installing drivers .. iPC picks up ZTE Diagnostic port instead of emergency driver |
i got the qualcomm driver but have problem with installing the correct drivers .. let me play with drivers first |
Sorry i failed to installed Correct driver for infinity QLM Device manager only Showing " ZTE handset Diagnostic Interface ( DFU ) " |
