Old 07-03-2017, 17:40   #1 (permalink)
rashidurgsm's Avatar
Member: 2409568
Sonork: 100.1652609
Thanks Meter: 22
frp romve error k88 zte cm2 [ v1.14 ]
Operation : Reset Settings [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 652 [MSM8952]
ID_BLOCK_S : 0125B725
ID_BLOCK_I : 009720E1
ID_BLOCK_E : 00040000
ID_BLOCK_L : 3CA0EF2EDAAC1EF8C13B98DB86A539AC
ID_BLOCK_L : 9172769AC33D8DAAF934593A84D06928
Use CM2 Internal Loader
Error : Prepare target failed! Unsupported SecureType!
Send log and report.log to support! Include device info also!
Reconnect Power/Cable!
Old 07-05-2017, 12:03   #2 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 461
you found any other solutioN ?>?>
Old 07-05-2017, 12:08   #3 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 584
y not use the latest ver.? you have old ver. so maybe it is not supported during that time
Old 07-05-2017, 13:02   #4 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 461
i have problem in installing drivers .. iPC picks up ZTE Diagnostic port instead of emergency driver
Old 07-05-2017, 13:08   #5 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 584
try to use edl cable for easy detection of emergency boot
Old 07-05-2017, 13:21   #6 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 461
i got the qualcomm driver but have problem with installing the correct drivers ..
let me play with drivers first
Old 07-05-2017, 13:40   #7 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 461
Sorry i failed to installed Correct driver for infinity QLM
Device manager only Showing " ZTE handset Diagnostic Interface ( DFU ) "
Page generated in 0.25048 seconds with 7 queries
