06-11-2010, 14:09 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | g"five f3 white screen after flash pls help |
The Following User Says Thank You to umarmsn For This Useful Post: |
06-14-2010, 06:42 | #5 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | hello bro first i did flash this file (M7026LDJWT_HF_PCB01_GSM_MT6223_S00.KAAM7026DJWT_T F_2_02_331__fullflash_20100607-193959.B0M) but i did not check the original version before flash |
06-14-2010, 07:04 | #6 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | but now it has been show the version **** that logs ==== log: [6/14/2010 11:27:53 AM] ==== COM3 [VCP2] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:7DC2:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #01 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #02 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #03 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #04 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #05 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #06 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #07 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #08 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #09 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #0A in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #0B in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #0C in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #0D in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #0E in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #0F in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb number of flash chip/regions detected: 10/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #01 in region #00... flash: 7F227E220A2201:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.07, database date: 16.01.2010): M7026LDJWT_HF_PCB01_GSM_MT6223_S00.KAAM7026DJWT_TF _2_02_302.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 07 sw version: M7026LDJWT_HF_PCB01_GSM_MT6223_S00.KAAM7026DJWT_TF _2_02_302.BIN project-id: KAAM7026DJWT_TF_2.02.302, 00000000 code offset: 00000000 ffs offset/size [02]: 00380000/00080000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00380000 flash: 7F227E220A2201:2AEA0000000000 checking area [00000000]: 00080000-003FFFFF... ffs/eeprom found near: 00390000 Detected ffs/eeprom address is non-standard: 00390000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00390000 detecting ffs/eeprom size... ffs/eeprom size: 00070000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00390000-003FFFFF detecting ffs/eeprom structure pass 1... ......... detect standard ffs/eeprom location pass #1... ............... detect extended ffs/eeprom location pass #1... ............. detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: M7026LDJWT_HF_PCB01_GSM_MT6223_S00.KAAM7026DJWT_TF _2_02_302.BIN detecting firmware build... ............. firmware build: KAAM7026DJWT_TF_2.02.302KONKA23D_328_GEMINI_09A_HW 2010-03-0109-21 detecting product-id... ................ done detecting languages... ............ language parameters detected detected languages: En Hi Ar sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Finished, time used: 58 sec Remove/Install battery now ! |
06-14-2010, 07:07 | #7 (permalink) |
No Life Poster Join Date: Sep 2006 Location: some where in india
Member: 350232 Status: Offline Thanks Meter: 207 | one most common and imp thing is before doing any china handset if it is in on condition .make full backup first. now u have read from working set and write on your set |
06-14-2010, 22:15 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try this file: flashfiles/ChineseMiracle/_MT6223/4m/M7026LDJWT_HF_PCB01_GSM_MT6223_S00.KAAM7026DJWT_TF _2_02_315__G`Five-F3_4m_En_Hi_Ar.B0M.bin |
07-04-2010, 23:13 | #13 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
if you dont know original software version- you are in truble. Now only PCB code can bring light to this problem. You must diassemble phone and search for printed short version code. Only by this code we can try to suggest correct flash file for flashing | |
