Old 09-18-2010, 03:53   #1 (permalink)
Registered User
Member: 690799
Thanks Meter: 157
G-five F5 during calling restrt, software fault
Hi!
I have 3pcs g-five f5 model with same problem : when receiving or making calls , set auto restart. I know this is 100% software fault.
any one have tested flash file????
plz share.
for information : similar kind problem i already faced with G-five f3 & f2 , problem solved only with flash with tested flash file.
Thanks in advance for help on this.
Old 09-18-2010, 09:35   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please let us know following:
1. did you try format FFS/IMEI restore?
2. have you tried to call 112 with removed SIM card? what result you get?
3. what is phone software version?
Old 09-18-2010, 09:38   #3 (permalink)
sajidshah50's Avatar
Member: 1016490
Thanks Meter: 290
bro also check ur voice changer option.sometime it creates this problem due to voice changer on....if on.....plz off it......otherwise sw fault
Old 09-19-2010, 02:55   #4 (permalink)
Member: 950629
Thanks Meter: 105
Yes try to call 112 without sim , if problem exist then check HW(PA,battery,battery con)
If 112 call making without problem then check SW.
Most of F5 found with this problem because of the IMEI. please check the IMEI.
Old 09-19-2010, 09:21   #5 (permalink)
Registered User
Member: 690799
Thanks Meter: 157
1.without sim 112 call absolute ok
2. Imei is there , G-Five all imei now registered By BAT
3. software version :M7026LDJWT_HF_PCB01_GSM_MT6223_S00.KAAM7026DJWT_T F_2_01_205__G5-F5_4m_En_Hi_Ar.B0M
As i said above, I already face same kind problem with G-five F2 & F3 mobile & solved by flashing with following files :
http://www.mediafire.com/?lwc98w1zl04fb6c
http://www.mediafire.com/?80zd458l2mpk0fz
I have tried above filed with F5, all is ok except Display become blue.
Plz help ,
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
Page generated in 0.13659 seconds with 9 queries
