07-12-2010, 07:25 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | g five model:ap3 blank display after format COM50 [VCP0] selected module v3.15 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2C03:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC227E22632260:18E59F00000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.6B2FCA11.[M5130_PCB01_GPRS_MT6225_S00.M5130_SW_JWT_TV_ROTATE _11COUNTRY_A15.BIN_619B32DA].rpl rom info detection finished ==================== New firmware detected (v.3.15, database date: 20.06.2010): M5130_PCB01_GPRS_MT6225_S00.M5130_SW_JWT_TV_ROTATE _11COUNTRY_A15.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: 6B2FCA11 rom info ver: 05 sw version: M5130_PCB01_GPRS_MT6225_S00.M5130_SW_JWT_TV_ROTATE _11COUNTRY_A15.BIN project-id: M5130_SW_JWT_TV_ROTATE_11COUNTRY_A15, DA329B61 code offset: 00000000 ffs offset/size [01]: 01C00000/00400000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01C00000 standard ffs/eeprom offset confirmed: 01C00000 detecting ffs/eeprom size... ffs/eeprom size: 00400000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01C00000-01FFFFFF detecting ffs/eeprom structure pass 1... ............................... ffs/eeprom: detect std location pass #1... .................................................. ............................................... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: M5130_PCB01_GPRS_MT6225_S00.M5130_SW_JWT_TV_ROTATE _11COUNTRY_A15.B detecting firmware build... .................................................. .................................................. ............................ .................................................. .................................................. ............................ done detecting product-id... .................................................. .................................................. ............................ done detecting languages... .................................................. ...................... language parameters detected detected languages: En Fr Es Id Th Tr Hi Urdu Farsi Pt Ar file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M 5130_PCB01_GPRS_MT6225_S00.M5130_SW_JWT_TV_ROTATE_ 11COUNTRY_A15.B__system_log_6B2FCA11_619B32DA_2010 0712-114818.B0X.bin Finished, time used: 3 min 3 sec Remove/Install battery now ! pls help for that problem |
07-12-2010, 08:23 | #2 (permalink) |
No Life Poster Join Date: May 2007 Location: INdIa
Member: 517316 Status: Offline Thanks Meter: 185 | If you have made flash backup then flash it.......... other wise u need this file M5130_PCB01_GPRS_MT6225_S00.M5130_SW_JWT_TV_ROTATE _11COUNTRY_A15.BIN or u can also try your luck by flashing some similar files from support. |
07-14-2010, 07:42 | #5 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
on which condition you rcv the set ? If display was OK then why not you take backup ? Now you need this flash file - M5130_PCB01_GPRS_MT6225_S00.M5130_SW_JWT_TV_ROTATE _11COUNTRY_A15.BIN Collect it from any working set | |
07-15-2010, 05:28 | #8 (permalink) | |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
what do next procedure sir this file i got from phone :M7026LDJWT_HF_PCB01_GSM_MT6223_S00.KAAM7026DJWT_T F_2_02_315__fullflash_20100714-095041.B0M | |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
Blue LEDs in your Display SUPER! | GM | Nokia Hardware & Hardware Repair | 0 | 06-25-2000 12:47 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
blue Display in Nokia Cellphones | TheDon | Nokia Hardware & Hardware Repair | 0 | 10-29-1999 18:28 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
