10-13-2010, 17:41 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | G right l800 eeprom and firmware COM9 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:BE03:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.24, database date: 01.10.2010): R206AF_ANX_F14_PCB01_GPRS_MT6225_S00.R206AF_ANX_F1 4_VT_V01_091112.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: R206AF_ANX_F14_PCB01_GPRS_MT6225_S00.R206AF_ANX_F1 4_VT_V01_091112.BIN project-id: R206AF_ANX_F14_VT_V01_091112, 00000000 code offset: 00000000 ffs offset/size [01]: 00E40000/001C0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E40000 flash: EC240200000000:2AEA0000000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00E60000 Detected ffs/eeprom address is non-standard: 00E60000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E60000 detecting ffs/eeprom size... ffs/eeprom size: 001A0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E60000-00FFFFFF firmware area: 00000000-00E5FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: R206AF_ANX_F14_PCB01_GPRS_MT6225_S00.R206AF_ANX_F1 4_VT_V01_091112__ffs... file saved: C:\Documents and Settings\Administrator\Desktop\blue toth\R206AF_ANX_F14_PCB01_GPRS_MT6225_S00.R206AF_A NX_F14_VT_V01_091112__ffs_20101013-075814.B0E.bin flash: EC240200000000:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2AEA0000000000 Finalization Done Finished, time used: 7 min 52 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
10-14-2010, 20:16 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! flashfiles/ChineseMiracle/_MT6225/R206AF_ANX_F14_PCB01_GPRS_MT6225_S00.R206AF_ANX_F1 4_V02_091028__L800_16m_En_Ru_Fr_Es_It_De_Ml_Id_Th_ Vn_Tr_Farsi_Pt_Ar.B0M.bin |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
