G-star GM208 Hi I have a china phone with this model G-Star GM 208 which is dead i try to write the file 2CM_Nokia-6300_TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE_1 6m_En_Fr_Vn_Ru_Ar_Th_Cn_w_eeprom.B0M.bin and it says flash erase error heres the logs COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash security area recalculation disabled write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8A01]... CPU: MT6219 high speed boot disabled high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 80008000801292:80808000000000 flash: B000B101800080:B000B100000000 flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb detecting chip #01 in region #00... flash: B000B004800080:B000B000000000 flash: B000B004800080:B000B000000000 flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb detecting chip #02 in region #00... flash: B000B101800080:B000B100000000 flash: B000B101800080:B000B100000000 flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb detecting chip #03 in region #00... flash: B000B004800080:B000B000000000 flash: B000B004800080:B000B000000000 flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Area: Firmware flash: B000B101800080:B000B100000000 flash: B000B101800080:B000B100000000 Write: Firmware error: error# 000000A9 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 08:3[01]: VPP < VPPLK during program or erase operation. error: flash write error: 00000000:00002000 error: error# 000000A9 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 08:3[01]: VPP < VPPLK during program or erase operation. error: flash write error: 00000000:00002000 Write Fail Finished, time used: 103 sec Remove/Install battery now ! is there any chance that this is hardware related? or is there any trick that i can do to write this flash file. |
hello! use full charged battery and repeat writing on slower speed |
here's the log in slowest baud rate. . . COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8A01]... CPU: MT6219 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 80008000801292:80808000000000 flash: B000B101800080:B000B100000000 flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb detecting chip #01 in region #00... flash: B000B004800080:B000B000000000 flash: B000B004800080:B000B000000000 flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb detecting chip #02 in region #00... flash: B000B101800080:B000B100000000 flash: B000B101800080:B000B100000000 flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb detecting chip #03 in region #00... flash: B000B004800080:B000B000000000 flash: B000B004800080:B000B000000000 flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... slowest Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Area: Firmware flash: B000B101000000:B000B100000000 Write: Firmware error: error# 00003030 80:7[00]: Device is busy; program or erase cycle in progress; SR[0] valid. 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 00200000:00002000 error: error# 00003030 80:7[00]: Device is busy; program or erase cycle in progress; SR[0] valid. 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 00200000:00002000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 714 sec Remove/Install battery now ! |
at 29% it always says erase error. |
bro wt results u have for formating ?????? can u show us the fomatting log .. complete format |
log of format COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: erase flash chip Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8A01]... CPU: MT6219 high speed boot disabled high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb detecting chip #01 in region #00... flash: B000B004000000:B000B000000000 flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb detecting chip #02 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb detecting chip #03 in region #00... flash: B000B004000000:B000B000000000 flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb detecting chip #01 in region #00... flash: B000B004000000:B000B000000000 flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb detecting chip #02 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 02/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 2 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: B000B101000000:B000B100000000 checking area[00000000]: 00000000-007FFFFF... flash: B000B004000000:B000B000000000 checking area[00800000]: 00000000-007FFFFF... eeprom/ffs found near: 00C10000 Detected eeprom/ffs address is non-standard: 00C10000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00C10000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 003F0000 ffs chip: 01 eeprom/ffs area: 00800000:00410000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: B000B101000000:B000B100000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: B000B101000000:B000B100000000 Erase: chip 1 of 2 flash: B000B004000000:B000B000000000 Erase: chip 2 of 2 Finalization Done Finished, time used: 135 sec Remove/Install battery now ! |
ohhh............. Action: erase flash chip Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8A01]... u erased Whole Chip??? ...hmmmm.. well now try writing the firmware ... and show log....... and use fully Charged Battery... |
writing firmware . . . COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: write NOR flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8A01]... CPU: MT6219 high speed boot disabled high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb detecting chip #01 in region #00... flash: B000B004000000:B000B000000000 flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb detecting chip #02 in region #00... flash: B000B101000000:B000B100000000 flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb detecting chip #03 in region #00... flash: B000B004000000:B000B000000000 flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... slowest Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Area: Firmware flash: B000B101000000:B000B100000000 Write: Firmware error: error# 00003030 80:7[00]: Device is busy; program or erase cycle in progress; SR[0] valid. 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 00200000:00002000 error: error# 00003030 80:7[00]: Device is busy; program or erase cycle in progress; SR[0] valid. 20:5[01]: Erase fail or program sequence error when set with SR[4,7]. 10:4[01]: Program fail or program sequence error when set with SR[5,7]. error: flash write error: 00200000:00002000 00000000000000000000000040000000000000000000000000 00000000000000000000000000000000000000000000000000 00400000000000000000000000000000000004010000000000 00000000000000000000000000004000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000040000000000000000000004000000000000000 FEFF0100004080000000000000000000400000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000002000000000000 0000000000 detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 1398 sec Remove/Install battery now ! Again it stop on 29% |
