Old 05-22-2008, 12:25   #1 (permalink)
Member: 42049
Thanks Meter: 7
G-star GM208
Hi I have a china phone with this model G-Star GM 208 which is dead i try to write the file
2CM_Nokia-6300_TELSDA26_05C_PCB01_GPRS_MT6226_S01.BASECODE_1 6m_En_Fr_Vn_Ru_Ar_Th_Cn_w_eeprom.B0M.bin
and it says flash erase error
heres the logs
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
security area recalculation disabled
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6219:8A01]...
CPU: MT6219
high speed boot disabled
high speed disabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 80008000801292:80808000000000
flash: B000B101800080:B000B100000000
flash: Sharp LRS1393A, LRS1395-F1, LRS1828-F1 B 8Mb
detecting chip #01 in region #00...
flash: B000B004800080:B000B000000000
flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
error: error# 000000A9
20:5[01]: Erase fail or program sequence error when set with SR[4,7].
08:3[01]: VPP < VPPLK during program or erase operation.
error: flash write error: 00000000:00002000
Write Fail
Finished, time used: 103 sec
Remove/Install battery now !
is there any chance that this is hardware related?
or is there any trick that i can do to write this flash file.
Old 05-22-2008, 17:55   #2 (permalink)
Member: 148515
Thanks Meter: 10,951
hello!
use full charged battery and repeat writing on slower speed
Old 05-23-2008, 08:18   #3 (permalink)
Member: 42049
Thanks Meter: 7
here's the log in slowest baud rate. . .
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6219
high speed boot enabled
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Done
.damaged firmware
.damaged hardware
Write...
.damaged firmware
.damaged hardware
Area: Firmware
flash: B000B101000000:B000B100000000
Write: Firmware
error: error# 00003030
80:7[00]: Device is busy; program or erase cycle in progress; SR[0] valid.
10:4[01]: Program fail or program sequence error when set with SR[5,7].
error: flash write error: 00200000:00002000
Write Fail
Finished, time used: 714 sec
Old 05-23-2008, 08:56   #4 (permalink)
Member: 42049
Thanks Meter: 7
at 29% it always says erase error.
Old 05-23-2008, 09:15   #5 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
bro wt results u have for formating ?????? can u show us the fomatting log .. complete format
Old 05-23-2008, 10:42   #6 (permalink)
Member: 42049
Thanks Meter: 7
log of format
advanced flash detection disabled
Action: erase flash chip
Boot...
19200 fixed
Connecting, wait...
CPU: MT6219
high speed disabled
Boot Done
Initialize...
flash: B000B004000000:B000B000000000
Initialize Done
Set baud...
115200
Set baud Done
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
number of flash chip/regions detected: 02/01
total flash region size: 01000000
.damaged firmware
.damaged hardware
detecting eeprom/ffs area in 2 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-007FFFFF...
checking area[00800000]: 00000000-007FFFFF...
eeprom/ffs found near: 00C10000
Detected eeprom/ffs address is non-standard: 00C10000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00C10000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 003F0000
ffs chip: 01
eeprom/ffs area: 00800000:00410000-007FFFFF
Write...
Write Done
Finalization...
formatting...
Erase: chip 1 of 2
Erase: chip 2 of 2
Finalization Done
Finished, time used: 135 sec
Old 05-23-2008, 10:58   #7 (permalink)
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
ohhh.............
Boot...
19200 fixed
Connecting, wait...
u erased Whole Chip??? ...hmmmm..
well now try writing the firmware ... and show log.......
and use fully Charged Battery...
Old 05-23-2008, 11:46   #8 (permalink)
Member: 42049
Thanks Meter: 7
writing firmware . . .
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6219
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Done
.damaged firmware
.damaged hardware
Write...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
00000000000000000000000040000000000000000000000000 00000000000000000000000000000000000000000000000000 00400000000000000000000000000000000004010000000000 00000000000000000000000000004000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000040000000000000000000004000000000000000 FEFF0100004080000000000000000000400000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000002000000000000 0000000000
error: unexpected termination/freez: 00000000
Write Fail
Finished, time used: 1398 sec
Again it stop on 29%
Star Power: Sterling Silver Designer Inspired Bridal Style Shooting Star Pendant Neck IPMART ipmart WebShop 0 10-15-2009 15:20
Cable Compatible For Gstar GM208 For Infinity Box IPMART ipmart WebShop 0 07-09-2009 16:00
Star Wars WEG-1618 Star Tours Action Figure IPMART ipmart WebShop 0 09-22-2008 07:10
Mpeg4 GM208 flash erase error 00E20000 Denozaur Infinity-Box 5 07-29-2007 10:52
Page generated in 0.35909 seconds with 8 queries
