07-18-2016, 18:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | G-TiDE_A2 dead vibration only i do erase flash by error Code: Operation : Flash [ v1.19 ] ======= Flash Files set for flashing : [ MCU ] : SC77xx Infinity Package 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 93 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : User decide to make whole erase [FL] : FLASH_FULL_FORMAT executing , wait ... [FL] : FLASH_FULL_FORMAT Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now Update BootCode : u-boot-spl-16k.bin Write Data ... Write Data Ok! Update BootCode : u-boot.bin Erase block ... Block erase Ok! Write Data ... Write Data Ok! Write FSImage : prodnv.img Write Data ... Write Data Ok! Write CodeData : sc7731g_CP0_modem.bin Write Data ... Write Data Ok! Write CodeData : DSP_DM_Gx.bin Write Data ... Write Data Ok! Update NVM image : nvitem_w.bin Update NVM Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : sc7731g_modem_CP2_WCN_14E_W15.31.1_Release.bin Write Data ... Write Data Ok! Update NVM image : nvitem_wcn.bin Update NVM Data Ok! Erase Block : RuntimeData Erase block ... Block erase Ok! Write CodeData : logo_480x800.bin Write Data ... Write Data Ok! Write CodeData : fblogo_480x800.bin Write Data ... Write Data Ok! Write CodeData : boot.img Write Data ... Write Data Ok! Write FSImage : system.img Write Data ... Write Data Ok! Write FSImage : cache.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Write CodeData : recovery.img Write Data ... Write Data Ok! Process : Flush Flush Ok! Write FSImage : userdata.img Write Data ... FSImage : Make and Flush SPImage Write Data Ok! Elapsed: 00:02:34 Reconnect Power/Cable! |
07-18-2016, 18:46 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. That mean you flashed wrong FW version for your phone HW revision, seems. |
07-18-2016, 19:33 | #5 (permalink) |
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | look bro the real history i flashed its turned on with logo.. then isee erase option i say i try it to delete all virus flash ok but not vibration test oki Code: ==== Wait for phone... Phone found! [ 93 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Prepare test data ... Test flow #0 ... Test flow passed! Test flow #1 ... Test flow passed! Test flow #2 ... Test flow passed! Test flow #3 ... Test flow passed! Test flow #4 ... Test flow passed! Test flow #5 ... Test flow passed! Finalize Ok! Test passed successfully! Elapsed: 00:00:25 Reconnect Power/Cable! Code: Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 93 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : v133_gal_047 Model Brand : G-TiDE Model Device: v133_gal_047 AndrVersion : 4.4.2 BaseBand CPU: V133_GAL_044 CompileDate : 08/12/2015 09:48:32 Project Ver : KOT49H 14B_test-keys Model Ext : G-TiDE A2 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:16 Reconnect Power/Cable! |
07-18-2016, 19:55 | #6 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Read firmware from same phone,same Revision write to fault phone with Nvram update Ticked, But next time,there is smart Av button for Cleaning viruses |
07-18-2016, 20:12 | #7 (permalink) |
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | this frw is readed from the same phone before 2 months i do it reset schematic after that i have readed frw today its became virused |
07-19-2016, 16:59 | #12 (permalink) |
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | HI BRO FIRST THE VERSION IS EXTRACTED FROM THE SAME SET I DO BCKP BEFORE FLASH WITH select PAC/SC files Code: Device ExtInfo : G-TiDE A2 Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 93 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 93 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : v133_gal_047 Model Brand : G-TiDE Model Device: v133_gal_047 AndrVersion : 4.4.2 BaseBand CPU: V133_GAL_044 CompileDate : 08/12/2015 09:48:32 Project Ver : KOT49H 14B_test-keys Model Ext : G-TiDE A2 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:15 Reconnect Power/Cable! Code: Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 93 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
