Old 06-12-2006, 07:51   #1 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Sonork: 100.1577222
G50 Direct Unlock But See This ????
I got one G50 with SIm MEP Failed When Trying to Unlock i get This....
COM12 selected
Device: Panasonic G50,G51
Checking data, wait...
Action: Unlock
Boot...
Press and HOLD Power button !
Connecting, wait...
Release Power button !
Flash: 20227E22022201
Flash: 8CE59F00000000
Boot Done
Set baud...
115200
Set baud Done
Check Flash...
Check Flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Format file system...
area-01...
area requested/selected: 02/03
Format file system Done
Write...
Preparing...
Err: wrong answer[]
Err: write[03]: 017F8000
Retrying...
Err: wrong answer[]
Retrying...
Write Fail
Finished
Remove/Install battery now !
Time used: 48 sec
What To DO ????
Old 06-12-2006, 09:46   #2 (permalink)
Member: 126612
Flash write is failing at a specific address all the time .. 017F8000 ...
One of 2 things you can try ...
Manual reset first .. *01763*737381#
then try unlock again ... if not help than reflow your flash and try again ... Could be harware related ..
Old 06-12-2006, 09:55   #3 (permalink)
Member: 91045
Sonork: 100.1577222
Well i did the Manual Reset by the COde u pro
vided..then Unlock but Still Same ..about u said Hardware Related..Nopes not Mine Kinda JOB...InfinitySupport what do u suggest PLZ reply
Old 06-12-2006, 12:06   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Hi,
Download latest QModule from support area and try it. waiting for your result.
G50 for Unlock but See this ??? Amir-SkillZ Infinity-Box 0 06-12-2006 07:47
LG U8180 10A direct unlock . but phone still locked. crossings SonyEricsson (USB-Smart) 5 12-03-2005 17:57
unlock X60, I know it's verry easy, but SEE THIS pls !!! JAVA Good Panasonic 4 10-24-2005 11:03
nec c616 unlocked with direct unlocker, but will not dial out Neem111 NEC 3 03-09-2005 09:51
Page generated in 0.76900 seconds with 11 queries
