05-06-2005, 14:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 53
Member: 51154 Status: Offline Thanks Meter: 68 | G60 faulty cable and Unibox cables I've been using a serial G60 cable to unlock in the meantime, however I have been unable to Read Flash, it just says Connecting, then seems to do nothing. Its a shame because I have a G60 with Dutch, French, German, Italian, Spanish, and Turkish on, that other users may need. |
05-06-2005, 15:44 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! I think that regular Unibox cables have to work with InfinityBox too. Anyway, I'll check pinout and will inform you some time later. As about cable for G60/X100/X500/A200: Check attached picture. It can be that regular Unibox cables don't have pin1-pin6 connection, but this modification is required for flashing. B.R. InfinitySupport Last edited by InfinitySupport; 01-10-2007 at 18:28. |
05-06-2005, 16:28 | #3 (permalink) |
Member: 51154 Status: Offline Thanks Meter: 68 | Thanks Infinity, I'll try and get in touch with my reseller in the meantime to see if I can get a replacement G60 cable. Then hopefully I can get these languages to you |
05-24-2005, 19:58 | #4 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | @ infinity support mate by any chance you do not have the exact connections to the RJ45 to this connector? I have also problems with this cable only. thanks a lot al |
05-24-2005, 20:55 | #5 (permalink) | |
Maybe I understand your question not so good. Anyway, here is RJ-45 to G60 connector connections: RJ45 FEMALE. Connector pins up. From left to right RJ45 -> G60 2 -> 9 3 -> 8 7 -> 1 7 -> 6 B.R. InfinitySupport | |
05-24-2005, 22:07 | #6 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | geez this is what i call a fast reply in this cable it is not as you described mate.... 7 and 8 on RJ are conncted together. also. 1 and 6 are not shorted at all on connector. Trying to just remove unlock code and not even connecting . going to try new setup. thanks a lot al |
05-24-2005, 22:12 | #7 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | nothing am using the left side of the RJ with F-bus chosen and still getting this Device have to be POWERED-ON ! Connecting to device. Wait... Error: Device not powered or bad connection what can i trouble shoot more pls? thanks al |
05-24-2005, 22:22 | #8 (permalink) | |
I just see number of your posts, and I think it's no need to ask you to check COM port selection Connector: Pin-1 have to be connected to Pin-6 for flashing. Unlock/UserLock have to work w/o this pin short. But anyway, better make phone connector Pin-1 to Pin-6 connected. Phone have to be switched On before operation. Also, check box green LED pls (during unlock try). Do you see any green LED activity ? B.R. InfinitySupport | |
05-25-2005, 06:22 | #9 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | hi mate. green LED (Rx) turns ON only when the switch is turned on Mbus . If FBus is selected it does not turn on. That is this turns on only on the right hand side of the box. thanks al |
05-25-2005, 09:22 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! Both box switches have to be in UP position (Box power and F-BUS activated). If you use USB part of box, then you need to use left RJ-45. If you use COM cable, then use right RJ-45. Also, if you have any other G60 cable, can you try to use it ? B.R. InfinitySupport |
05-25-2005, 09:36 | #11 (permalink) |
Member: 51154 Status: Offline Thanks Meter: 68 | Hi Infinity Team I contacted my reseller as I said earlier in this thread and they sent me another RJ45 cable - still same problems I'm afraid... I contact connect at all using RJ45 cable and box, and I have tried every combination off connections. I can unlock and flash with regular serial (COM) cable plugged into my serial port of PC, but I cannot read the flash of any phone still. |
05-25-2005, 10:06 | #12 (permalink) | |
Could you, please, give us text from Log window when you tried to read flash ? We will try to check what is wrong. And as about G60 cable with our Unibox. Could you, pls, give us Log text too when you try to make any operation with our Unibox and G60 cable. Thank you ! B.R. InfinitySupport | |
05-25-2005, 13:14 | #13 (permalink) | |||
Member: 51154 Status: Offline Thanks Meter: 68 | Quote:
If you press STOP you get this Quote:
05-25-2005, 19:23 | #14 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | problem fixed. Had to rewire the cable. 7 and 8 on RJ were shorted too .. no idea why. seems the guy doing the cable was asleep did all functions including flashing and reading flash ok. thanks for the help mates and support al |
Z310 Pinout for USB cable and COM cable | GSM SNIPER | UST Pro II | 11 | 10-19-2006 21:45 |
cruiser cable and p9xxx cable drivers dont work together | taopheek | Cruiser Suite | 0 | 07-01-2006 11:11 |
nbox and ufs and redbox and martech and unibox cables and new mmcunlocker in stock | USMAN MOBILES | Main Sales Section | 0 | 03-01-2006 22:03 |
Cruiser Cables and compatible cables | tical | Cruiser Suite | 2 | 03-23-2005 22:25 |
Diferences betwen griffin cables and tornado cables??? | sergioems | Griffin | 1 | 04-14-2004 02:09 |
