05-23-2016, 11:39 | #1 (permalink) |
Junior Member Join Date: Jul 2008
Member: 812868 Status: Offline Thanks Meter: 3 | G610 error after change emmc g610 error after change emmc: ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 202 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 80812805C0000A00BBDAF6BFFCF3EF5D Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! plz help me. |
The Following User Says Thank You to padidehteam For This Useful Post: |
05-24-2016, 03:20 | #3 (permalink) |
Freak Poster Join Date: Jun 2012 Location: bali
Member: 1778254 Status: Offline Sonork: sornork id Thanks Meter: 36 | emmc detek ok, but dram emmc not detect maybe bad replease emmc or emmc broken |
The Following User Says Thank You to putu1996 For This Useful Post: |
05-24-2016, 07:07 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Resolder eMMC normally, or check, probably you touch CPU, or made it too much overheat. |
05-28-2016, 15:41 | #6 (permalink) |
Member: 812868 Status: Offline Thanks Meter: 3 | 1-cpu does not overheat 2-resolder emmc 3-change emmc [DA_ERROR] : DA Load failed! ErroCode : 0x2007 DA_START_LOAD_FAILED Boot Error! 3 mainboard = g610-u20 1 mainboard = g610-u00 |
05-28-2016, 15:51 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | This tells nothing. Need full logs. Make sure you install correct memory ( same , as before ) |
05-28-2016, 15:57 | #8 (permalink) |
Member: 812868 Status: Offline Thanks Meter: 3 | log full: Wait for phone... Phone found! [ 163 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 4B0001153030534AC4B8034D55509563 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x00000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2007 DA_START_LOAD_FAILED Boot Error! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! |
05-28-2016, 16:02 | #9 (permalink) |
Freak Poster Join Date: Jul 2013 Location: CAIRO.EGYPT
Member: 1981679 Status: Offline Thanks Meter: 86 | I do change Emmc for Alcatel ot-7041d before This error message from Emmc IC resolder or change again. This is my opinion. أرسلت من C6903 بإستخدام تاباتلك |
05-28-2016, 16:02 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Now you installed SAMSUNG KJS00M. DA correctly see it info, but DRAM not initialized. Does that phone has exactly same eMMC installed? |
