01-30-2017, 21:57 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | g630 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 077922D7 ID_BLOCK_I : 008140E1 ID_BLOCK_L : EC144E8827B3B8AB94C90B14D3AE2626 ID_BLOCK_L : 5023ED3C31A00A9B3EF9D20B199482C9 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Files in Chain : 21 Flashing now Flashing : gpt_main0.bin Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : emmc_appsboot.mbn Flashing : NON-HLOS.bin Flashing : persist.img Flashing : boot.img Flashing : recovery.img Flashing : cust.img Flashing : cache.img Flashing : misc.img Flashing : system.img Flashing : userdata.img ProgStart : start 3686400, num 8 ProgFinish : Read back verify failed at sector -434909199,num sectors 3686400 Flash Error , No ACK message! Check Battery charge , Cable Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
01-30-2017, 22:00 | #2 (permalink) |
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 077922D7 ID_BLOCK_I : 008140E1 ID_BLOCK_L : EC144E8827B3B8AB94C90B14D3AE2626 ID_BLOCK_L : 5023ED3C31A00A9B3EF9D20B199482C9 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Huawei ProdName : G630-U10 ProdModel : G630-U10 Device : hwG630-U10 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 |
01-30-2017, 22:12 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. What Format FS says? Use WIPE mode. Then open MemoryTool , write GPTBACKUP from FW folder. Try start phone. |
