Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2009 Location: portugal Age: 35
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks: 1,609
| G6608 no net ...need some advice sir....how to fix???fone ask for pin then no net.....maybe softwere????? |
| | #5 (permalink) | |
| Quote:
ON preferred networks PORTUGAL NETWORK´S NOT SHOW NON.... vailble list is : VODAFONE ES 21401 SFR FR 20810 VODAFONE UK 23415 VODAFONE.DE 26202 VODAFONE IT 22210 VODAFONE NL 20404 VODAFONE GR 20205 RO VODAFONE 22601 VODAFONE HU 21670 VODAFONE EG 60202 VODAFONE IRL 27201 VODAFONE AU 50503 VODAFONE AL 27602 VODAFONE MT 27801 VODAFONE CZ 23003 VODAFOINE TR 28602 VODAFONE TR 28602 | |
| | #6 (permalink) | |
| Quote:
trying to select model: /G6608 model selected via command line: Huawei-G6608 Device: Huawei-G6608 Initialization done In most cases you can read "firmware" instead of "full flash", it may helps to save a lot of time with the same functionality. Suggestion: read "firmware" now Do you want to read "firmware" instead of "full flash" ? ==== [28-04-2012 13:41:42] ==== COM11 [VCP0] selected module v4.25 Device: Huawei-G6608 Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00D000000015 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6235:8C00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: G6608SSW.C221.M49.00.08 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: THEMISPLUS_HW_SS_VDF_BOOTLOADER_V005_MT6235B_G6608 SSW_C221_M49_0 nfi area detection (4 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: THEMISPLUS_HW_SS_VDF_PCB01_GPRS_MT6235B_S01.G6608S SW_C221_M49_00_08.BIN project-id: G6608SSW.C221.M49.00.08, 07093EFA code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.4.25, database date: 19.04.2012): THEMISPLUS_HW_SS_VDF_PCB01_GPRS_MT6235B_S01.G6608S SW_C221_M49_00_08.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: support@infinity-box.biz or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\InfinityBox\MModule\Huawei-G6608_THEMISPLUS_HW_SS_VDF_PCB01_GPRS_MT6235B_S01. G6608SSW_C221_M49_00_08__firmware_20120428-143932.B4M.bin Disconnect... done file saved: c:\InfinityBox\MModule\backup_security\Huawei-G6608_THEMISPLUS_HW_SS_VDF_PCB01_GPRS_MT6235B_S01. G6608SSW_C221_M49_00_08__system_log_20120428-143950.B4X.bin Finished, time used: 58 min 8 sec Remove/Install battery now ! ==== [28-04-2012 14:40:03] ==== COM11 [VCP0] selected module v4.25 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6608 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8C00:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235C,E00 Date: 2000.00.00 Version: 1.0 Version: G6608SSW.C221.M49.00.08 Version: CKT35_09A_HW 90 byte(s) read imei: 35609004293778 connection Ok 196 byte(s) read reading data... reading data #2... building new data... writing data... 184 byte(s) read reading data... reading data #2... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 17 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [28-04-2012 14:42:36] ==== COM11 [VCP0] selected module v4.25 Device: Huawei-G6608 Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00D000000015 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6235:8C00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: G6608SSW.C221.M49.00.08 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: THEMISPLUS_HW_SS_VDF_BOOTLOADER_V005_MT6235B_G6608 SSW_C221_M49_0 nfi area detection (4 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: THEMISPLUS_HW_SS_VDF_PCB01_GPRS_MT6235B_S01.G6608S SW_C221_M49_00_08.BIN project-id: G6608SSW.C221.M49.00.08, 07093EFA code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.4.25, database date: 19.04.2012): THEMISPLUS_HW_SS_VDF_PCB01_GPRS_MT6235B_S01.G6608S SW_C221_M49_00_08.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: support@infinity-box.biz or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== warning: can not format: HW_STORAGE_NOR is not present Format... autodetection mode... Format done Disconnect... done file saved: c:\InfinityBox\MModule\backup_security\Huawei-G6608_THEMISPLUS_HW_SS_VDF_PCB01_GPRS_MT6235B_S01. G6608SSW_C221_M49_00_08__system_log_20120428-144621.B4X.bin Finished, time used: 3 min 45 sec Remove/Install battery now ! Action: "repair imei" Model: Huawei-G6608 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 new imei-1: 356090042937780 verification Ok Finished, time used: 18 sec Remove/Install battery now ! Are you sure that your phone really blocked by network ? operation canceled WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [28-04-2012 14:49:33] ==== COM11 [VCP0] selected module v4.25 Device: Huawei-G6608 Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6235:8C00:8A00 status: FF bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 07D4:S_BROM_DOWNLOAD_DA_FAIL error: last error: 07D4:S_BROM_DOWNLOAD_DA_FAIL Disconnect... done Finished, time used: 17 sec Remove/Install battery no HERE´S BACKUP Huawei-G6608_THEMISPLUS_HW_SS_VDF_PCB01_GPRS_MT6235B_S01. G6608SSW_C221_M49_00_08__firmware_20120428-143932.B4M.rar download - 2shared | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | Yesterday 19:20 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 1 | 06-02-1999 16:23 |
| need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 05-26-1999 11:35 |
