04-27-2010, 18:39 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 218901 Status: Offline Thanks Meter: 64 | G6610 Not Unlock module v3.37 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:FB0F:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: G6610.CA.SS.MN.P42.I308.02.03 Version: TINNO25_08A_GEMINI_HW 80 byte(s) read imei: 35868800000015 connection Ok 185 byte(s) read reading data... reading data #2... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 28 sec Remove/Install battery now ! still locked. |
The Following User Says Thank You to pr1mux For This Useful Post: |
05-06-2010, 18:11 | #4 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 576154 Status: Offline Thanks Meter: 23 | method smart fast COM5 [VCP0] selected modulo v3.38 Servicio: Huawei-G6610 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "sp-unlock" Metodo unlock: standard fast ====> Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6225:8A05:8A00]... CPU: MT6225 chip: 0001A03:0008 status: FF Tamaٌo del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done ====> Iniciar ... detecting chip #00 in region #00... Flash EC227E22632260:0AEA0000000000 Flash AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 numero de flash chip/regiones detectadas: 01/01 Iniciar Done ====> Seleccionar velocidad ... 921600 Seleccionar velocidad Done ====> Iniciar bootcode ... Iniciar bootcode Done ====> Comprobar la integridad del firmware ... usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_ SS_MN_P63_I308_04_09.BIN project-id: G6610.CA.SS.MN.P63.I308.04.09, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Comprobar la integridad del firmware Done ====> Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done ====> Backup de datos requeridos ... Flash EC227E22632260:0AEA0000000000 Backup de datos requeridos Done ====> Revisiَn de datos requeridos ... .................................................. ................... lock area found .................................................. ................... lock area found Revisiَn de datos requeridos Done ====> Operacion Especial ... detecting parameters to apply patch area 1... .................................................. .................................................. ............................ error: area 1 can not apply patch detecting parameters to apply patch area 2... ..... required data found Flash EC227E22632260:0AEA0000000000 Flash EC227E22632260:0AEA0000000000 Escribir area 2 (pass 1) .................................................. .................................................. ....................... area 2 patch applied Ok Operacion Especial Done ====> Escribir ... Flash EC227E22632260:0AEA0000000000 Flash EC227E22632260:0AEA0000000000 Escribir lock-area-1 Flash EC227E22632260:0AEA0000000000 Flash EC227E22632260:0AEA0000000000 Escribir lock-area-4 Escribir Done ====> Finalizado ... Finalizado Done Finalizado, tiempo usado: 3 min 30 sec Quite/coloque la bateria ahora ! process well. continuous cell locked. Now I try other methods later |
05-06-2010, 18:49 | #5 (permalink) | ||
Member: 571744 Status: Offline Thanks Meter: 17 | I try this on my Huawei G6610 But No Luck Here... STANDARD Procedure... Quote:
Readed FLASHFILE Uploading........... TIA | ||
05-06-2010, 22:15 | #7 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 593061 Status: Offline Thanks Meter: 19 | g6610 not unlock reset settings Code: COM6 [VCP0] selected module v3.37 Device: Huawei-G6610 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9803:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:0AEA0000000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_SS_MN_P63_I308_04_09.BIN project-id: G6610.CA.SS.MN.P63.I308.04.09, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Huawei-G6610_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_SS_MN_P63_I308_04_09__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Huawei-G6610_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_SS_MN_P63_I308_04_09__ffs_20100506-161504.B0E.bin flash: EC227E22632260:0AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC227E22632260:0AEA0000000000 Finalization Done Finished, time used: 4 min 1 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! unlock method: standard Code: COM6 [VCP0] selected module v3.37 Device: Huawei-G6610 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9803:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:0AEA0000000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_SS_MN_P63_I308_04_09.BIN project-id: G6610.CA.SS.MN.P63.I308.04.09, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Huawei-G6610_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_SS_MN_P63_I308_04_09__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Huawei-G6610_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_SS_MN_P63_I308_04_09__ffs_20100506-160520.B0E.bin flash: EC227E22632260:0AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................................................................................................................................ error: area 1 can not apply patch detecting parameters to apply patch area 2... ................................................................................................................................ error: area 2 can not apply patch Special operation Done ====> Write ... flash: EC227E22632260:0AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 5 min 2 sec Remove/Install battery now ! |
05-07-2010, 11:35 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, We want to buy this phone for research, we will pay for phone and delivery. If you can sell this phone to us, please, contact to [email protected] or ICQ 561878718 and talk about delivery. Thank you ! |
05-18-2010, 19:11 | #10 (permalink) | |
Freak Poster Join Date: Jan 2005 Location: Here, there & Everywhere.....
Member: 110575 Status: Offline Thanks Meter: 98 | Quote:
I bought my phone 120 USD, but the problem is the Shipping is to expensive... If you want I can buy to you, just give me a message... | |
05-21-2010, 10:07 | #11 (permalink) | |
If you have simlocked G6610 please, send a e-mail to [email protected] We will pay for phone and we make DHL delivery by our account. | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
