| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: pakistan
Member: 334999 Status: Offline Thanks: 219
| G7010 not unlock done with MM module 3.77 plz help here is report COM18 [VCP1] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: ESPC113B146SSC Version: VER.B 116 byte(s) read imei: 1400E600370016 connection Ok 217 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 8 byte(s) read error: source data size is less than expected 205 byte(s) read reading data... reading data #2... reading data #3... 0 byte(s) read warning: communication fault error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! |
| The Following 3 Users Say Thank You to asif_ae For This Useful Post: |
| | #2 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Jun 2009 Location: infinity-box
Member: 1043909 Status: Offline Thanks: 8,755
| Quote:
G7010 can not be unlocked yet, because we have made software for G6620 only. If you want to get software for G7010, make this: Read full flash from G7010 (select G6620 model) and send full flash backup file (or link) to rd@infinity-box.com We will check your file and try to make update. Last edited by YellowBoss; 02-27-2011 at 13:12. | |
| | #3 (permalink) | |
| here is the link of full flash backup of G7010 plz check urgent Quote:
http://rapidshare.com/files/45019311...fullflash_2011 thanks in advance | |
| The Following 2 Users Say Thank You to asif_ae For This Useful Post: |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2002 Location: Spain Age: 42
Member: 12126 Status: Offline Sonork: 1575463 Thanks: 65
| Here is full flash of G7010 backup read with Infinity box read as G6620. also sent to support. MEGAUPLOAD - The leading online storage and file delivery service regards bcnboy |
| The Following User Says Thank You to bcnboy For This Useful Post: |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2009
Member: 1059036 Status: Offline Thanks: 4
| problems solved COM4 [VCP0] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: ESPC113B146SSC Version: VER.B 116 byte(s) read imei: 05002700960037 connection Ok 217 byte(s) read reading data #2... reading data #3... reading data #4... reading data #5... 8 byte(s) read error: source data size is less than expected 205 byte(s) read reading data... reading data #2... reading data #3... 0 byte(s) read warning: communication fault error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! |
| | #7 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 8,964
| @GSM FREE please, post here information about pinout that you have used. Also, I hope in nearest hour new software for G7010 test will be uploaded, I'll give a link in current thread |
| | #8 (permalink) |
| @all who have Huawei-G7010 on hands for unlock: 1. use this software: http://www.infinity-box.com/download...v3.77_ver2.rar 2. make full flash backup for emergency case 3. make unlock via "read unlock codes" method only 4. post here your results |
| The Following 37 Users Say Thank You to InfinitySupport For This Useful Post: | 69eyes, abidjon, aliazer, arx, avtarkaint, d.jain, Dr.Batista, fabicel, FullFLASHgSMPH, goodman1980, gsmstyle_1, IVERSON12312, javedsf, johnysofts, josedavido, joseph2003, JUNAID ARAIN, justincel, kmaxmax, kpdahal, M.Irfan786, milandhal, misterG, mort83, ncoolsoft., N_YOUNGBY, oscarjr85, Qaisar Mahmood, raselcox, sadiq123, tarun batla, tousgsm, tynch000, WENMODE29, yawarniazi, ysraeldark, zeroualot_7 |
| | #9 (permalink) | |
| not successful unlock done with version 3.77 ver2 Quote:
here is log report and not show any code just phone lock code show COM18 [VCP0] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G7010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: ESPC113B146SSC Version: VER.B 115 byte(s) read imei: 35391504210012 connection Ok 216 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 204 byte(s) read reading data... 188 byte(s) read lock[1] code: + 12345678 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 10 sec Remove/Install battery now ! here is my flash file link i have already post this first of all http://rapidshare.com/files/45019311...fullflash_2011 Last edited by asif_ae; 03-01-2011 at 03:34. | |
| The Following 4 Users Say Thank You to asif_ae For This Useful Post: |
| | #10 (permalink) | |
| here are pictures Quote:
http://rapidshare.com/files/450355130/g7010.jpg http://rapidshare.com/files/450355147/g7010_2.jpg | |
| | #13 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008
Member: 725834 Status: Offline Thanks: 378
| chack this link,,,,,,,,,,,,,,,,,,,,,, MEGAUPLOAD - The leading online storage and file delivery service |
| The Following User Says Thank You to MIRPUR AJK For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-19-2012 18:47 |
| 6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 04-14-2012 14:48 |
| HELP!!! BACKGROUND SCREEN LOGO | Michael Go | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-25-2011 23:56 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 06-09-1999 17:04 |
