G7010 unlock softwere error 3 Hi Infinity team I unlocked G7010 without taking the ful flash backup now it says softwere error 3 the log is here COM5 [VCP0] selected module v4.27 Model: Huawei-G7010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: GBRC154B267SSCPAB Version: VER.C 115 byte(s) read imei: 35391504668164 Finished, time used: 13 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! error: can not create required data Shutdown... done Finished, time used: 8 sec Remove/Install battery now ! please infinity team help |
Hello, I think it's not a problem after unlock. According to operation log I see that your phone was already damaged before unlock process. We have no solution for this phone yet. |
attach your original IMEI |
thanks for the reply infinity team i flashed the phone with these these flash files now phone is dead Huawei-G7010_HUAWEI53_09B_PCB01_GPRS_MT6253_S00[1].NICC64B263SSCBDD.BIN_FLNTY6701111184KC_En_Es.B0M Huawei-G7010_ffs_11[1].ESPC113B146SSC.BIN_FLNTY6701111184KC.B0E is there anyway to make it alive thanks |
Try to flash phone with different firmware, phone should be powered-on well without sim-card, but with sim-card it may be a problem. |
Thanks alot infinity team the phone is alive now but now it says softwere error 23 before it was error 3 attached the imei as well still gives error anyway to fix it |
Hello, As I told before - we have now any methods to repair this kind of faults. |
How to repair software error 23 |
use gb-key just 1sec and u are done |
