Originally Posted by said4
(Post 12399411)
here is log
After flash message still here Code:
Card found : S/N : 334FA6A3 , v0135
Operation : HW Test [ v1.58 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 1501004E355530304D02ADC282308081
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , M00U5
[eMMC] : FLASH_CID : 1501004E355530304D02ADC282308081
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x4B1992B149CA407999FBD6756B53A7FD
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , M00U5 , 0xE9000000 , 3728 MiB
[eMMC] : CID : 1501004E355530304D02ADC282308081
[eMMC] : MODE : SQ-WR
[FAILED : READONLY] : eMMC state seems as READ-ONLY !!!!
Operation Failed
Elapsed: 00:00:31
Reconnect Power/Cable!
Scatter Load Ok , BaseBand : MT6572 , Project : s538 , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : Samsung
Device Model : SM-G530H
Device CPU : MT6572
Device IntName : SM-G530H
Device Version : 4.4.2
Device Compile : 08.04.2016 3:42:04
Device Project : S538FW_4.4_V1.6
Device ExtInfo : SM-G530H
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:34
======= Flash
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s538 , Storage : EMMC
Setting : AFF verify : Disabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3843 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000E3000000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s538.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:01:23
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:01:45
Reconnect Power/Cable! | FS reset Code:
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Format/Reset Error!
Operation Failed
Elapsed: 00:00:29
