07-25-2014, 20:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | galaxy SQ9600 spd 6530 formating done Chinese Miracle II [SPD module] v 0.07 Operation : Check/Read Info [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Check/Read Info [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Check/Read Info [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! Operation : Check/Read Info [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! Operation : Check/Read Info [ v0.07 ] Normal Normal , 1 : Power On phone. Insert USB cable ( Normal USB cable ) Service Service , 1 : Insert USB cable ( Use adapter or special cable ) Service , 2 : Insert battery Service , 3 : If boot not start - press 'Power' button shortly ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Read User Code [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! Operation : Read User Code [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0018 0000 [0] Flash VEN : GigaDevice , GD25LQ128 [0] Flash CAP : 01000000 Check data... Can take some time User Code : 1070 Done! Elapsed: 00:00:38 Reconnect Power/Cable! Operation : Read FullFlash [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Operation : Read FullFlash [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0018 0000 [0] Flash VEN : GigaDevice , GD25LQ128 [0] Flash CAP : 01000000 Read Flash Content Read Ok , collect info ExtInfo : S650C_128X64_TJ_LA6EN_V301_130412_SQ Project : SC6530_s650 HWInfo : SC6530_s650 Compile : 04-17-2013 14:34:43 Set FileInfo : Model Vendor : sq 9600 Model Name : samsung ExtInfo Data : french Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6530_01000000_S6 50C_128X64_TJ_LA6EN_V301_130412_SQ_04172013143443_ french__sq 9600-samsung.bin Done! Elapsed: 00:02:59 Reconnect Power/Cable! Operation : Format File System [ v0.07 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Format File System [ v0.07 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Format File System [ v0.07 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Format File System [ v0.07 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Format File System [ v0.07 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 265 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00C8 0060 0018 0000 [0] Flash VEN : GigaDevice , GD25LQ128 [0] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to fokal2008 For This Useful Post: |
