11-13-2007, 12:59 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: India
Member: 107448 Status: Offline Thanks Meter: 29 | Gaoxinqi-A818 phone not ready (auto restart) Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 115200 Set baud Done Identification... reading... detecting structure... converting data... done protocol ver: 04 ver. sw1: MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18.BIN ver. sw2: MAUI.05C.W06.24.MP.V18 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok structure: 2nd [standard] (or higher) generation Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... Write Done Finished, time used: 79 sec Remove/Install battery now ! |
11-13-2007, 16:06 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I don't see any problems and any explanation of problem. What is the problem and what kind of update you request ? MT6228 CPU with NAND supported already. |
11-14-2007, 06:37 | #6 (permalink) |
Member: 107448 Status: Offline Thanks Meter: 29 | Gaoxinqi-A818 mobile restart with sim ( 6228 NAND ) -------------------------------------------------------------------------------- Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] warning: NOR flash chip not supported or not detected (see here the error) 0n 2 mobile Initialize Done Set baud... 115200 Set baud Done Identification... reading... detecting structure... converting data... done protocol ver: 04 ver. sw1: MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18.BIN ver. sw2: MAUI.05C.W06.24.MP.V18 ffs offset/size: 02000000/06000000 id-page Ok nfi area detection finished: Ok structure: 2nd [standard] (or higher) generation Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... Write Done Finished, time used: 79 sec Remove/Install battery now ! but finished . But the mobile problem is same like that. pls help |
11-14-2007, 11:34 | #7 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | Finished, time used: 79 sec Set baud... 115200 mmmmm did you do it on [safe] or [complete] mode? i guess its not formatted, i think this is too short to format the phone, but i think infinity support might have another idea.... BR Mansi |
11-14-2007, 17:20 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | There is no any errors in this log. This phone has no NOR chip, only NAND chip exist so software inform you that there is no NOR chip installed in phone. Please, try to think during log reading. What to do: please, follow the instruction exactly: http:///vbb/showthread.php?t=447277 |
11-15-2007, 10:02 | #9 (permalink) |
Member: 107448 Status: Offline Thanks Meter: 29 | Problem In Safe & Complete IN SAFE FORMAT Action: reset settings Model: Autodetect 6228 NAND Checking data, wait... COM1 selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6228:8A02:8A02]... Connecting, wait... error: can't finalize test moide Operation failed ! Finished, time used: 19 sec Remove/Install battery now ! IN COMPLETE FORMAT Do you want to continue ? COM1 selected Device: Autodetect 6228 NAND Checking data, wait... Action: NAND reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND id: ECF10095 page size: 800+40 pages/block: 40 bits i/o: 08 address cycles: 04 blocks: 0400 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:00F100000095 [08400000] NOR chip is not installed Initialize Done Set baud... 115200 Set baud Done Identification... reading... detecting structure... converting data... done protocol ver: 04 ver. sw1: MT6228_05C_PCB04_GPRS_MT6228_S02.MAUI_05C_W06_24_M P_V18.BIN ver. sw2: MAUI.05C.W06.24.MP.V18 ffs offset/size: 02000000/06000000 id-page Ok warning: probably incorrect/unknown source file nfi area detection finished: Ok structure: 2nd [standard] (or higher) generation Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... Write Done Finished, time used: 80 sec Remove/Install battery now ! ANY OTHER WAY TO RECTIFIVE (READY) THE MOBILE |
china phone camera module not ready | sesime | MC-Tool | 2 | 02-26-2010 19:58 |
i-Pmart BX Series RJ45 Cable Compatible For Gaoxinqi A818 For Infinity Box | IPMART | ipmart WebShop | 0 | 07-08-2009 10:50 |
Gaoxinqi-A818 phone's flashing problem with additional attachments | puksul | Infinity-Box | 13 | 09-12-2008 08:33 |
Gaoxinqi A818 Flash file needed | az cells | Infinity-Box | 1 | 07-31-2008 10:39 |
