Old 04-06-2010, 20:58   #1 (permalink)
ELGOAT's Avatar
Member: 225008
Thanks Meter: 11
Gb-160
need pinout lg gb-160
Old 04-06-2010, 21:01   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Try to use ordinary LG-C2500 cable.
Old 04-06-2010, 21:16   #3 (permalink)
ELGOAT's Avatar
Member: 225008
Thanks Meter: 11
ok, attempts to,,,,,,
Old 04-07-2010, 20:34   #4 (permalink)
Member: 1043909
Hello,
Please, keep me informed about your results.
Old 04-07-2010, 20:34   #5 (permalink)
Member: 1043909
Hello,
Old 04-08-2010, 22:00   #6 (permalink)
ELGOAT's Avatar
Member: 225008
Thanks Meter: 11
ok,
=== flash/unlock cable ===
keyboard top
_____
/12345\
_______
1: Gnd
3: box Rx/phone Tx (RJ45 pin-3)
4: box Tx/phone Rx (RJ45 pin-2)
log.
COM1 [VCP0] selected
module v3.33
Device: LG-GB160
Checking data, wait...
Action: "sp-unlock"
unlock method: standard fast
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:534A:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:2AEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: A7216_PCB01_GPRS_MT6223_S00.GB160AOL-01-V10A-CAO-XXX-OCT-30-2009.BIN
project-id: GB160aOL-01-V10a-CAO-XXX-OCT-30-2009, 00000000
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID is absent
ffs/eeprom address assigned: 00C00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
lock area found
lock area found
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
area 1 patch applied Ok
Special operation Done
====> Write ...
Write: lock-area-1
Write: lock-area-4
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 1 min 24 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to ELGOAT For This Useful Post:
Old 04-09-2010, 12:41   #7 (permalink)
Member: 1043909
@ELGOAT
Thanks a lot, we will update pinout database ASAP.
Old 07-15-2010, 14:13   #8 (permalink)
Member: 1065216
Thanks Meter: 91
Its same lg gw300 uart cable?
Old 07-15-2010, 15:23   #9 (permalink)
Member: 1043909
Yes, it's the same cable.
HP 2133 Mini-Note - C7-M 1.6 GHz ULV - RAM 1 GB - HDD 120 GB - Chrome9 - Gigabit Ethe IPMART ipmart WebShop 0 09-08-2008 07:50
HP 2133 Mini-Note - C7-M 1.2 GHz ULV - RAM 1 GB - HDD 120 GB - Chrome9 - Gigabit Ethe IPMART ipmart WebShop 0 09-08-2008 07:50
ASUS Eee PC 901 20G (8.9\\\' Display, 1.6 GHz Intel ATOM Processor, 1 GB RAM, 20 GB S IPMART ipmart WebShop 0 09-08-2008 07:50
ASUS Eee PC 900 16G (8.9\\\' Display, Intel Mobile CPU, 1 GB RAM, 16 GB Solid State D IPMART ipmart WebShop 0 09-08-2008 03:40
Page generated in 0.18958 seconds with 9 queries
