06-14-2005, 06:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Age: 44
Member: 93610 Status: Offline Thanks Meter: 45 | X500 after flash - formatting FMGR..... Plz if anyone knows plz help me... |
06-14-2005, 11:07 | #3 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
It's normal situation. After you flash new firmware in any of these models: X100, A200, G60, X500, at first power-on try phone have to rebuild some internal data. And you will see this message: "Formatting FMGR" This process can takes several minutes. After this procedure complete, your phone will start normally. So, don't worry, just wait 1-2 minutes and then your phone will be Ok. B.R. InfinitySupport | |
06-14-2005, 16:21 | #5 (permalink) | |
Hm... Strange... 1. How long time you already see this message ? 2. Try to remove battery and power on phone again. Do you see this message again ? 3. Try to write other Flex file. What is the results ? 4. What do you mean "dead phone" ? What is this phone history ? B.R. InfinitySupport | |
06-15-2005, 12:35 | #6 (permalink) |
Member: 93610 Status: Offline Thanks Meter: 45 | X500...formatting FMGR..... I saw this message for about 2 munites, then phone display gets blank and power off. I tried all the flash files in available in the website. Even after removing and powering on, i see the same message. dead phone means...a no power phone. |
06-15-2005, 13:28 | #7 (permalink) | |
I think that it can be hardware fault too. F.e. defected flash chip. Looks like phone try to rebuild internal data at first power-on-try, but this data damaged even after rebuilding, so phone can't start normally. Check hardware, please. B.R. InfinitySupport | |
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] | jus_chillin | Cyclonebox | 19 | 03-29-2010 11:57 |
S75 freezes after flash. Formating fixes it, but all files are gone | James_S | S-Gold Based Phones | 7 | 07-18-2008 04:34 |
motorola e365 formating fmgr... ? | gsmsikar | Infinity-Box | 1 | 04-11-2007 18:08 |
c261 formatting fmgr | c_ahmad79 | Infinity-Box | 6 | 11-15-2006 21:38 |
X500 after flash .. camera failed ?? | rampe | Infinity-Box | 3 | 05-18-2005 11:25 |
