07-21-2006, 14:12 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Kepler22 Age: 46
Member: 93787 Status: Offline Sonork: 1646397 Thanks Meter: 9 | GD55 imei repair problem,how to solve this error? Device: Panasonic GD55 Checking data, wait... Action: Imei repair Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 04225000000001 Flash: 54E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Err: Imei not found or damaged Err: Operation aborted Finished Remove/Install battery now ! Time used: 11 sec how to sove this error? br; maxijazz |
07-23-2006, 12:37 | #5 (permalink) |
Member: 93787 Status: Offline Sonork: 1646397 Thanks Meter: 9 | eprom reading succesfull but when i try to load this file on flash tabs,always error: Loading file [version 02]... data error Loading failed, probably damaged data file. another que is,after read flash operation on gd55,can i use this file as firmware? br; maxijazz COM1 selected Device: Panasonic GD55 Checking data, wait... Action: Read Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! Flash: 04225000000002 Flash: 54E59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... In progress[eeprom-01]... In progress[eeprom-02]... Finished Remove/Install battery now ! Time used: 17 sec Loading file [version 02]... data error Loading failed, probably damaged data file. |
07-23-2006, 15:50 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | After all imeis used: nothing to do (just for info: Imei located not in eeprom) Use backup as firmware: possible only after you will send backup to [email protected]. We will test/convert file and will upload in support area ASAP. |
07-24-2006, 17:38 | #7 (permalink) | |
Member: 93787 Status: Offline Sonork: 1646397 Thanks Meter: 9 | Quote:
hi,im just looking for a firmware file that contains Turkish language for gd55,thats why i read flash from a working phone.if you know any of the firmwares at support contains Turkish lanuage please inform me about it.and,if i send you some imeis which are desired to write to my phones to repair,can you add them to the list on infinity software? br; maxijazz | |
07-25-2006, 22:07 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, List of flash files/languages here: http://www.infinity-box.com/download...p?id_file=1703 Imeis in list: I can't add any imei in list that you see for your phone. This list generated by software for each phone (and this list always different). |
how to solve this error ! | nikunj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 01-23-2010 13:35 |
Help how to solve this error | her_pearl | SpiderMan | 1 | 12-23-2009 04:26 |
Phone problem how to solve samples error here | FullFLASHgSMPH | Cyclonebox | 14 | 03-29-2009 13:01 |
7100t how to solve this error | SAMEER TAHIR | BlackBerry (RIM) | 1 | 11-24-2008 11:56 |
