Old 04-23-2007, 17:37   #1 (permalink)
Member: 48873
Thanks Meter: 2
GD55 Repair imei ERR
GD55 imei 25A3A100000051 Repair err
COM4 selected
Device: Panasonic-GD55
Checking data, wait...
Action: Imei repair
Boot...
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 04225000000002
flash: 54E59F00000000
Boot Done
Set baud...
460800
Set baud Done
Check Flash...
Check Flash Done
Check space...
Check space Done
Check parameters...
file saved: backup_error_log_20070423-231544.01L.bin
Err: Imei not found or damaged
Err: Operation aborted
Finished
Remove/Install battery now !
Time used: 13 sec
help me
GD55 flash ID korea 84VD22184FM -70
The Following User Says Thank You to gsmtp2 For This Useful Post:
Old 04-23-2007, 18:06   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hi,
There is no need to attach backup files here.
Flash phone with other flash files from support area (newest firmware) and imei will looks like good.
Old 04-24-2007, 11:58   #3 (permalink)
ebu mohammed-emin's Avatar
Member: 263993
Sonork: 100.1612432
Thanks Meter: 172
witch kabel work for gd55
i dont find in support area the pnouts for it
an i try twogd55 with g50 kabel and x66 kabel but still not work.
Old 04-24-2007, 17:05   #4 (permalink)
Member: 130995
GD55 pinout attached
Old 04-25-2007, 19:49   #5 (permalink)
Member: 263993
Sonork: 100.1612432
Thanks Meter: 172
thx alot
ebu mohammed-emin
Old 05-01-2007, 16:30   #6 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
I have same problem! can not write IMEI, I want to change IMEI of the GD55 but same error. why can not! I need to change its IMEI.
regards
Old 05-01-2007, 16:42   #7 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
what is your imei now?
Old 11-19-2007, 13:39   #8 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
hello!
sorry for the late answer.. now I got a new GD55 one digit of the IMEI is not same.. I want to write an IMEI but can not.. does the IMEI Chnage option really works for GD55?
regards..
Old 11-19-2007, 17:18   #9 (permalink)
Member: 130995
Of course this option really work but some limitations exist, software allow to write only some digits, not all. It's limitation due to phone arhitecture.
Old 02-11-2009, 21:14   #10 (permalink)
jufong's Avatar
Member: 120908
Thanks Meter: 37
can be emei eror because eprom corupted
maybe
how abaut you sir
Old 02-12-2009, 20:27   #11 (permalink)
Member: 130995
maybe
how abaut you sir
Hello,
Please, explain your idea more detailed. What eeprom and what error you talk exactly ?
Old 12-25-2010, 14:22   #12 (permalink)
Member: 194907
Thanks Meter: 102
Application: C:\Program Files\InfinityBox\QModule\QModule.exe
Loading data, wait...
[Infinity Box] v2.21
S/N: -------
Wait...
Current device: Panasonic-GD55
Done
COM1 [Serial0] selected
Action: Imei repair
Boot...
Connecting, wait...
flash: 04225000000001:54E59F00000000
flash: Fujitsu 84VD22183Ex T 4Mb
Boot Done
Set baud...
115200
Set baud Done
Check Flash...
Check Flash Done
Check space...
Check space Done
Check parameters...
file saved: C:\Program Files\InfinityBox\QModule\backup_error_log_2010122 4-142003.01L.bin
error: Imei not found or damaged
error: Operation aborted
Finished
Help me infinity team gd 55 imei change error ....
Old 12-26-2010, 16:26   #13 (permalink)
Member: 130995
Hello,
What is this phone history and what is the problem exactly ?
Is it good working or damaged phone ?
W490 sw version not found, Repair PDS err 9B T Mobile Smart-Clip 0 04-15-2009 14:23
i need gd55 repair porgram??? saidgoren Panasonic 1 06-20-2006 06:48
Panasonic GD55 Repair from unlock prob mob Panasonic 1 12-05-2003 20:32
GD55 unlock / IMEI change needed AMDcpu Panasonic 0 09-28-2003 17:32
How repair Reading err 537 on Sagem ?? florinmar Infineon C16X M51 & ARM7 M52 BASED 6 08-26-2002 07:04
Page generated in 0.41105 seconds with 8 queries
