Old 06-14-2006, 17:13   #1 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
GD67 Conncection Problem
I cant connect this phone with Infinity to flash
I get this error:
PowerOn phone now...
Enter flash mode fail. Try again.
When I press power ON button for sometime as usual, The software shows this error, and phone comes ON.
What could the problem be ?
BTW
I am using cable that came with Infinity and also unibox cable on USPI and both same problem !!!!!!!!!
Old 06-14-2006, 19:47   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hi,
Download "GD67 v1.07" from support area "beta/test software" section.
Old 06-15-2006, 00:02   #3 (permalink)
Member: 130995
Gd67 v1.07 moved in "Updates" section in support area.
Old 07-14-2006, 12:15   #4 (permalink)
Member: 132858
I did everithing said i support, flash ok, unlock ok, both this perfect, but phone it´s still locked. Any idea?
thx in advance
Old 07-14-2006, 17:37   #5 (permalink)
Member: 132858
Problem solved, great tool of work infinity team!
Regards
Old 06-09-2008, 16:37   #6 (permalink)
..:HGSM:..'s Avatar
Member: 62419
i have the same problem with 2 pieces, used Gd67 v1.07 cable gd92
Old 09-21-2008, 14:39   #7 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
i have now 1 phone in hand, same problem i face, how to flash and unlock it?
Old 09-22-2008, 21:49   #8 (permalink)
Member: 130995
Hello,
Please, double check that phone bottom connector contacts is clean and is not damaged.
Old 11-19-2008, 08:44   #9 (permalink)
jaytrio's Avatar
Member: 351593
guys how can i flash gd67 in infinity.im using v1.07a....
this phone autoshut off when sim inserted...............
br
Old 11-19-2008, 14:21   #10 (permalink)
Member: 130995
Hello,
Did you tried to make 112/emergency call without sim card ?
What is the results ?
gd67 connection problem richyrask Panasonic 2 07-05-2003 13:27
GD67 Cable Problem s7event Panasonic 1 06-11-2003 11:50
GD67 backlight problem Jt Panasonic 1 06-08-2003 19:48
GD67 strange problem!!!HELP!!! gsm4dcs Panasonic 2 04-30-2003 23:01
GD67 GPRS problem mkoparan Panasonic 1 02-17-2003 08:12
Page generated in 0.30297 seconds with 11 queries
