Old 04-12-2005, 17:33   #1 (permalink)
Member: 2899
Thanks Meter: 6
"x300 problem"
hi
just bought this product,tried to unlock a x300 but nothing!!heres what i did,
installed the drivers,soft, chose x300 ,left the toggle switch on,left the front toggle switch up,used the provided leads(the ones with the jack)chose the correct port settings,(i think)whatever it was showing in divice manager,it was 17, i then chose 1,then 2 but no commiunication!! please help,dont know what else to do,
br
farry
Old 04-12-2005, 18:02   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello !
1. I think that COM-Port COM-17 was correct. Check it again, please.
Here is attached picture of "Port" section in DeviceManager.
Correct port (on my picture) is COM5 (Infinity USB serial port).
2. You have to use for X300 cable with "G50" label. It's cable with Hands-Free jack with 4 (four) metal pins (pls, see attached picture too).
3. Insert cable into left RJ-45 connector (near Rx/Tx LEDs).
4. F-BUS/M-BUS switch on front side have to be in up position (F-BUS)
5. When you select correct COM port, start software and press "Unlock" button, you have to see GREEN LED is blinking very fast. This means that COM port selected Ok.
6. Now press phone Power button (Red button) for several seconds. When progress-bar start to move you can releas Power button.
B.R.
InfinitySupport
Originally Posted by farry
hi
br
farry
Old 04-12-2005, 18:12   #3 (permalink)
Member: 2899
Thanks Meter: 6
hi there
the divice manager is almost same but one thing which was differentwhen installing the usb driver it was saying sphere usb not infinity!!how is that possible? please help,i think that we r getting somewhere!!
br
farry
Old 04-12-2005, 18:18   #4 (permalink)
Member: 130995
Hm... Interesting
Anyway, try to make this:
select COM port with text "USB" near it, run software and press "Unlock" button.
If you will see that GREEN LED blinkig very fast - this means you have selected COM port Ok.
Do you see green led blinking ?
B.R.
InfinitySupport
Old 04-12-2005, 18:24   #5 (permalink)
Member: 2899
Thanks Meter: 6
hi
yes at one stage,i did see a green light blinks fast,i will check my steps and your tips, and will post results,thns for the fast reply, i will double check in device manager to see infinity usb!!.
br
farry
Old 04-13-2005, 09:46   #6 (permalink)
Member: 2899
Thanks Meter: 6
hi infinitysupport
problem solved,after charging the batterrie for few more minutes,it unlocked the phone ,in 42 seconds!!,supper tool,thnx for the help though,
br
farry
ps,lets hope u bring x70 solution!!!,just kidding!!
Old 04-13-2005, 10:36   #7 (permalink)
Member: 130995
hi infinitysupport
br
farry
Hello !
Thanks to you too for good words !
We hope you will be satisfied with our product in future too.
B.R.
InfinitySupport
Old 04-13-2005, 12:34   #8 (permalink)
Member: 2899
Thanks Meter: 6
so is that mean u will add x70!!! lol
br
farry
Old 04-16-2005, 20:59   #9 (permalink)
Member: 130995
br
farry
I think now you already have answer to your question
Our main idea:
"Even small real work is more important than big future promises"
(c) Infinity-Box 2005
B.R.
InfinitySupport
Old 04-18-2005, 13:44   #10 (permalink)
needi's Avatar
Member: 18303
Thanks Meter: 3
Well its really hard to connect to phone.Everything seems ok.....did the all above.but no success.Is there any special settings for this.
Old 04-18-2005, 13:49   #11 (permalink)
needi's Avatar
Member: 18303
Thanks Meter: 3
I am trying with X300 and A100 phone.....using G50 cable.BUt no success with both the phones....
Old 04-18-2005, 13:55   #12 (permalink)
Member: 128745
Thanks Meter: 16,936
@ needi
try not to insert connector completly inside the phone ,
leave a little space , dont press it hard
Best Regards
Infinity-Box Team
The Following User Says Thank You to Infinity-Box For This Useful Post:
Old 04-18-2005, 14:01   #13 (permalink)
needi's Avatar
Member: 18303
Thanks Meter: 3
No success this way also....can u come to ICQ.
Old 04-18-2005, 16:12   #14 (permalink)
Member: 128745
Yes sure
Please post ure ICQ number here so i can add you
Best Regards
Infinty-Box Team
Old 04-18-2005, 20:08   #15 (permalink)
galaxi's Avatar
Member: 5915
Thanks Meter: 7
i have flashed & unlocked A100 and X300 success without any problem using G50 cable
"X300 Phone lock Code" PLZ HELP meisam JAF Xtras 10 05-18-2007 22:38
Mw30260 display "Parameter problem"??? colin42100 Infineon C16X M51 & ARM7 M52 BASED 15 07-14-2004 18:51
"ufs dct3 problem" farry UFS2 + UFS3-Tornadoflasher 3 02-02-2004 18:41
a200 "lcd problem" Moosani Samsung Hardware Repair 0 04-06-2003 00:00
"another sl45 problem" farry x1x to x45/x50 6 08-16-2002 08:56
Page generated in 0.22979 seconds with 9 queries
