Gd67 & Gd68 hi Infinity team i can flash gd68 by GD67 with 1.05C.... it's the same ?? |
Yes. You can do it w/o pb |
wath the solution ! with cable GD92 ! i have this message : Power On phone now... Enter flash mode fail. Try again. !!!! |
Hi, Pls, check com-port selection, maybe wrong port selected. Also, what is with phone when you start software and press phone power button ? |
when i switched power on i have always this message Enter flash mode fail. Try again. |
What is with phone ? Can it power-on normally or maybe it's dead phone ? Did you checked com port selection ? |
The phone is dead i hve checked the mothercard it is ok its a flash problem |
Hi, it's impossible to flash dead phones (erased boot core) with Infinity (abd with original flasher too). Its need to use external flash chip programmer to program desoldered flash chip directly. |
@festhache I you go to reprogram GD67/ or GD87 - uff - i hate GD87 flash reprograming/ flash IC-s on external progammer MUST on all cases readout flash dump, PATCH ONLY boot code and rewrite back /now you can flash it with downloader/, because if you rewrite eeprom zone, then phone can be flashed, will enter in test mode via CB2000, but important data locked to HW shall be mismatched and phone cannot be turned on and used. |
gd 68 dead i am trying to flash but there Flash data not loaded i downloaded flash file on support gd 67 but how to take the flash file in run ofter |
