Old 11-26-2005, 12:14   #1 (permalink)
..:HGSM:..'s Avatar
Member: 62419
Thanks Meter: 66
Exclamation Gd67 & Gd68
hi Infinity team
i can flash gd68 by GD67 with 1.05C.... it's the same ??
Old 11-26-2005, 13:02   #2 (permalink)
kasner's Avatar
Member: 56469
Thanks Meter: 136
Yes. You can do it w/o pb
Old 11-26-2005, 14:56   #3 (permalink)
..:HGSM:..'s Avatar
Member: 62419
Thanks Meter: 66
wath the solution !
with cable GD92 !
i have this message :
Power On phone now...
Enter flash mode fail. Try again.
Old 11-26-2005, 15:13   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
Pls, check com-port selection, maybe wrong port selected.
Also, what is with phone when you start software and press phone power button ?
Old 11-26-2005, 15:26   #5 (permalink)
..:HGSM:..'s Avatar
Member: 62419
Thanks Meter: 66
when i switched power on i have always this message
Old 11-26-2005, 16:53   #6 (permalink)
Member: 130995
What is with phone ? Can it power-on normally or maybe it's dead phone ?
Did you checked com port selection ?
Old 11-26-2005, 18:41   #7 (permalink)
..:HGSM:..'s Avatar
Member: 62419
Thanks Meter: 66
The phone is dead i hve checked the mothercard it is ok
its a flash problem
Old 11-26-2005, 19:12   #8 (permalink)
Member: 130995
Hi,
it's impossible to flash dead phones (erased boot core) with Infinity (abd with original flasher too). Its need to use external flash chip programmer to program desoldered flash chip directly.
Old 11-27-2005, 07:39   #9 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
@festhache
I you go to reprogram GD67/ or GD87 - uff - i hate GD87 flash reprograming/ flash IC-s on external progammer MUST on all cases readout flash dump, PATCH ONLY boot code and rewrite back /now you can flash it with downloader/, because if you rewrite eeprom zone, then phone can be flashed, will enter in test mode via CB2000, but important data locked to HW shall be mismatched and phone cannot be turned on and used.
Old 02-25-2010, 15:25   #10 (permalink)
Member: 951640
Thanks Meter: 3
gd 68 dead i am trying to flash but there Flash data not loaded i downloaded flash file on support gd 67 but how to take the flash file in run ofter
Old 02-25-2010, 16:41   #11 (permalink)
Member: 1043909
Thanks Meter: 60,926
http://forum.gsmhosting.com/vbb/showthread.php?t=936588
Unlock remotely all GU87 GD87 GD67 GD68 GD87e all versions gsmsupport Main Sales Section 0 06-01-2004 21:22
Is it possible to flash GD68 with flash for GD67? Bogi Panasonic 13 04-25-2004 18:44
I need Channel Box for GD67 , GD68 kisa55 Panasonic 5 01-20-2004 20:40
Gd67 GD68 French.. speedcomtop Panasonic 4 09-28-2003 01:17
GD67 and GD68 FLASHER and LANG ACTIVATOR Bazooka Panasonic 7 02-07-2003 11:29
Page generated in 0.27438 seconds with 9 queries
