10-10-2017, 08:49 | #1 (permalink) |
Major Poster Join Date: Jun 2017
Member: 2727668 Status: Offline Thanks Meter: 19 | Getting error on secure boot even with replace DA ?? Code: Start at : [10/10/2017 / 12:50:09 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 440001453330344622B4013251D04293 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! Finish at : [10/10/2017 / 12:50:25 PM] |
10-10-2017, 14:21 | #4 (permalink) |
Member: 2727668 Status: Offline Thanks Meter: 19 | It's not dead phone Working phone with frp activated Comio brand Also if i not hold key then getting another error Now i done with sp tool by manual format frp address With same hold both volume keys... |
