vignesharmy55 | 08-19-2011 10:15 | g'five ap3 flash file here is flash log Code:
COM4 [VCP1] selected
module v4.00
Device: _Autodetect MT6205-6239 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
M5130_PCB01_GPRS_MT6225_S00.M5130_SW_JWT_TV_ROTATE_11COUNTRY_A15__fullflash_20110818-183108.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:E203:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC227E22632260:18E59F00000000
flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
otp offset: 00000000
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 02000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
warning: wrong data size at 0x000017C8, retry...
read error recovered
warning: wrong data size at 0x000073C8, retry...
warning: wrong data size at 0x000317C8, retry...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is absent
warning: wrong data size at 0x00470E28, retry...
startup code area #1 is Ok
startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.539FBBD1.[M5130_SW_JWT_TV_ROTATE_11COUNTRY_A35.BIN_C6495A73].rpl
New firmware found (v.4.00, database date: 14.08.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
device-id: 539FBBD1
rom info ver: 05
sw version: M5130_SW_JWT_TV_ROTATE_11COUNTRY_A35.BIN
project-id: M5130_SW_JWT_TV_ROTATE_11COUNTRY_A35, 735A49C6
code offset: 00000000
ffs offset/size [01]: 01C00000/00400000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 01C00000
standard ffs/eeprom offset confirmed: 01C00000
detecting ffs/eeprom size...
ffs/eeprom size: 00400000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:01C00000-01FFFFFF
firmware area: 00000000-01BFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: M5130_SW_JWT_TV_ROTATE_11COUNTRY_A35__ffs...
warning: wrong data size at 0x01C09000, retry...
warning: wrong data size at 0x01C21400, retry...
warning: wrong data size at 0x01C27000, retry...
warning: wrong data size at 0x01C2C400, retry...
warning: wrong data size at 0x01C34000, retry...
warning: wrong data size at 0x01C39C00, retry...
warning: wrong data size at 0x01C3F800, retry...
warning: wrong data size at 0x01C41C00, retry...
warning: wrong data size at 0x01C4F800, retry...
warning: wrong data size at 0x01C67400, retry...
warning: wrong data size at 0x01C73400, retry...
warning: wrong data size at 0x01C79000, retry...
warning: wrong data size at 0x01C9CC00, retry...
warning: wrong data size at 0x01CA8800, retry...
warning: wrong data size at 0x01CAE400, retry...
warning: wrong data size at 0x01CC0800, retry...
file saved: C:\InfinityBox\MModule\M5130_SW_JWT_TV_ROTATE_11COUNTRY_A35__ffs_20110819-130752.B0E.bin
flash: EC227E22632260:18A59F00000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
rpl file not found: c:\InfinityBox\MModule\id.539FBBD1.[M5130_PCB01_GPRS_MT6225_S00.M5130_SW_JWT_TV_ROTATE_11COUNTRY_A15.BIN_619B32DA].rpl
rpl file not found: c:\InfinityBox\MModule\id.539FBBD1._M5130_PCB01_GPRS_MT6225_S00.M5130_SW_JWT_TV_ROTATE_11COUNTRY_A15.BIN_619B32DA_.rpl
startup code area #1 backup loaded
startup code area #1 calculation...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
file saved: c:\InfinityBox\MModule\backup_security\M5130_SW_JWT_TV_ROTATE_11COUNTRY_A35__system_log_539FBBD1_C6495A73_20110819-130912.B0X.bin
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\M5130_SW_JWT_TV_ROTATE_11COUNTRY_A35__system_log_539FBBD1_C6495A73_20110819-133352.B0X.bin
Finished, time used: 31 min 22 sec
Remove/Install battery now ! |
