12-13-2010, 14:48 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | gfive d11 need flash file module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 356072001834661 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E903:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 24.10.2010): JWT_Z137B_104_PCB01_GPRS_MT6225_S00.LB0MM73_8_32_1 _5T07M0412_M111.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: JWT_Z137B_104_PCB01_GPRS_MT6225_S00.LB0MM73_8_32_1 _5T07M0412_M111.BIN project-id: LB0MMB1.8.32.1.2T03M0413_M111, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC240200000000:18E59F00000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... .............................. ffs/eeprom: detect std location pass #1... .................................................. ..... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete error: ffs/eeprom detection failed element #2 error: can not detect default imei value Patch required data Fail Finished, time used: 1 min 49 sec Remove/Install battery now ! |
12-13-2010, 14:50 | #2 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | set information below customer gave to me dead condition when i make repaire blocked it does not successfull so pls guide me to will get successfull |
12-14-2010, 07:05 | #3 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | i got done flashing at this file JWT_Z137B_104_PCB01_GPRS_MT6225_S00.LB0MM73_8_32_1 _6T08M0420_M111__fullflash_20101214-105059.B0M.rar |
The Following User Says Thank You to umarmsn For This Useful Post: |
12-15-2010, 19:58 | #4 (permalink) | |
Sorry, I did not understand well. Did you repaired phone with this file or is it backup from damaged phone ? | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
