08-09-2015, 13:51 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Gfive FT03 SPD6531 read code format not supported Code: Operation : Read User Code [ v1.03 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Check data... Can take some time User Code : ¸ Done! Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Format File System [ v1.03 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Verify data... Can take some time Error while prepare! Please, send FlashDump + log to support! Reconnect Power/Cable! Operation : Read FullFlash [ v1.03 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B_6531.W13.07_Release Project : SC6531_PDA HWInfo : SC6531_PDA Compile : 12-15-2014 20:25:30 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_MOCOR_12B_6531.W13.07_Release_12152014202530.bin Done! Elapsed: 00:01:23 Reconnect Power/Cable! SPD6531_01000000_MOCOR_12B_6531.W13.07_Release_121 52014202530 |
08-10-2015, 07:57 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
this is dual flash chip phone? still we can't collect such phone - if you can send ur phone to JayDi we can try | |
10-21-2015, 11:07 | #4 (permalink) |
Insane Poster Join Date: Aug 2009 Location: Uk manchister
Member: 1089462 Status: Offline Sonork: 100.564333 Thanks Meter: 10 | [theft-proof lock]:123456 Looking for passwords,please wait... [Phone Lock] 1234 [Phone Lock] 1125 >>Looking for passwords complete. |
