10-29-2010, 15:03 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Gfive Mobile (CPU : 6253) No licence to produce I have brand new mobile i format it in complete mode just for test software.format sucess but mobile goes in "no licence to produce" state. Code: COM7 [VCP1] selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: A19BV10_GFIVE_DSIM_IT32DE_V02 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00.A19BV10_GFIVE_DSIM_IT32DE_V02.BIN project-id: A19BV10_GFIVE_DSIM_IT32DE_V02, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.25, database date: 24.10.2010): GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00.A19BV10_GFIVE_DSIM_IT32DE_V02.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\Documents and Settings\KK Mobile\Desktop\GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00.A19BV10_GFIVE_DSIM_IT32DE_V02__fullflash_20101029-175304.B0M.bin Format (HW_STORAGE_NOR)... Disconnect... done Finished, time used: 8 min 31 sec Remove/Install battery now ! flash backup: GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. A19BV10_GFIVE_DSIM_IT32DE_V02__fullflash_20101029-175304.B0M.bin Supporters please help me or decode file in infinity format . . . . |
10-31-2010, 12:17 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please post this backup writing LOG. we must see why you are "unable" to do this |
11-01-2010, 07:13 | #3 (permalink) |
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: write flash NAND write: Firmware GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. A19BV10_GFIVE_DSIM_IT32DE_V02__fullflash_20101029-175304.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... warning: incorrect header: 18F09FE518F09FE518F09FE518F09FE5 warning: can not detect header nfi area detection (0 cores) finished: failed error: unknown HW_STORAGE_NAND source file structure Finished, time used: 1 sec Remove/Install battery now ! |
11-02-2010, 09:16 | #6 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Hello firmware is erase from phone see attach picture i get this error on writing firmware. COM5 [VCP0] selected module v3.25 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware HUIYUE53_09A_PCB01_GPRS_MT6253_S00.6253_C77_ALX_N0 7_ML_A_V06__firmware_20101030-175543.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (230400)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... error: can not write flash: 0BD6:S_DA_NOR_BLOCK_DATA_UNSTABLE error: last error: 0BD6:S_DA_NOR_BLOCK_DATA_UNSTABLE Disconnect... done Finished, time used: 1 min 1 sec Remove/Install battery now ! ================================================== ======================= & here is complete writing eeprom logs COM5 [VCP0] selected module v3.25 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs HUIYUE53_09A_PCB01_GPRS_MT6253_S00.6253_C77_ALX_N0 7_ML_A_V06__ffs_20101030-175748.B0M.bin nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (230400)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done ==================== New firmware found (v.3.25, database date: 24.10.2010): This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 3 min 34 sec Remove/Install battery now ! |
11-03-2010, 09:09 | #9 (permalink) | |
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Quote:
Hello i dont use any other option i use only format option & i read full flash file before formating i have back file but not write on phone getting this error COM5 [VCP0] selected module v3.25 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware HUIYUE53_09A_PCB01_GPRS_MT6253_S00.6253_C77_ALX_N0 7_ML_A_V06__firmware_20101030-175543.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (230400)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... error: can not write flash: 0BD6:S_DA_NOR_BLOCK_DATA_UNSTABLE error: last error: 0BD6:S_DA_NOR_BLOCK_DATA_UNSTABLE Disconnect... done Finished, time used: 1 min 1 sec Remove/Install battery now ! | |
12-29-2010, 09:42 | #14 (permalink) | |
Crazy Poster Join Date: Jan 2006
Member: 222342 Status: Offline Thanks Meter: 12 | Quote:
COM31 [Serial2] selected module v3.25 Device: Autodetect 6253 NOR Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done error: NAND chip size is zero error: last error: 03F0:S_BUF_LEN_IS_ZERO Disconnect... done Finished, time used: 41 sec Remove/Install battery now ! | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
