11-22-2010, 09:22 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Gfive Mobile (CPU : 6253) No licence to produce solved Today i found same mobile with same firmware version with no problem in unit i jusr read eprom from unit and write it to my faulty unit. And problem solved ! Action: read ffs/eeprom NAND Code: interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: A19B_JWT_DSIM_TOSHIBA_V01 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00.A19B_JWT_DSIM_TOSHIBA_V01.BIN project-id: A19B_JWT_DSIM_TOSHIBA_V01, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 2Mb number of areas/bytes to read: 1:00200000 reading (HW_STORAGE_NOR)... file saved: C:\Documents and Settings\KK Mobile\Desktop\GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00.A19B_JWT_DSIM_TOSHIBA_V01__ffs_20101122-100932.B0M.bin Disconnect... done Finished, time used: 1 min 48 sec Code: skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00.A19B_JWT_DSIM_TOSHIBA_V01__ffs_20101122-100932.B0M.bin nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: A19B_JWT_DSIM_TOSHIBA_V01 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00.A19B_JWT_DSIM_TOSHIBA_V01.BIN project-id: A19B_JWT_DSIM_TOSHIBA_V01, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 2 min 1 sec Remove/Install battery now ! |
The Following 5 Users Say Thank You to KK Mobile For This Useful Post: |
11-23-2010, 05:54 | #3 (permalink) | |
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Quote:
Eprom file : http://rapidshare.com/files/43256816...122-100932.B0M Full flash backup of working unit : http://rapidshare.com/files/43256843..._20101122-1005 Regards: KK Mobile | |
The Following 2 Users Say Thank You to KK Mobile For This Useful Post: |
11-26-2010, 12:27 | #6 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Quote:
Phone Model Name C3_ANOKING http://rapidshare.com/files/433237831/GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. GD1180_V3_AINUOX_TOSHIBA_L1_V04__ffs_20101127-1603 COM3 [VCP0] selected module v3.25 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. GD1180_V3_AINUOX_TOSHIBA_L1_V04__ffs_20101127-160342.B0M.bin nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (230400)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: GD1180_V3_AINUOX_TOSHIBA_L1_V04 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. GD1180_V3_AINUOX_TOSHIBA_L1_V04.BIN project-id: GD1180_V3_AINUOX_TOSHIBA_L1_V04, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.25, database date: 24.10.2010): GOLDDRAGON53_JAVA_12832_09A_PCB01_GPRS_MT6253_S00. GD1180_V3_AINUOX_TOSHIBA_L1_V04.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 3 min 14 sec Remove/Install battery now ! | |
The Following User Says Thank You to rameez_gsm For This Useful Post: |
11-26-2010, 12:57 | #7 (permalink) |
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | i have another phone E5_MBO dead problem how i write flash file i write flash file i getting a error please solve this problem infinityteam i have many more phone... |
11-30-2010, 12:55 | #9 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | Quote:
01-14-2011, 16:37 | #11 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: India
Member: 237210 Status: Offline Thanks Meter: 90 | Quote:
02-27-2011, 21:28 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, try to use this new software: http://forum.gsmhosting.com/vbb/f425...y-box-1216399/ We are waiting for test report ! |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
