Old 05-27-2010, 07:01   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
g'five model:t33+, message not open
i have g'five model:t33+, my problem is message not open but it is only work menu otherwise message,contact,and any not working
pls check my logs and then post your sugession
====> Check firmware integrity ...
device parameters detection in progress...
flash: 2088C4FFFF0026:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.13, database date: 25.04.2010):
GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.HBA04BV3 0_HBAD_DSIM_ST3W0_V18.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.HBA04BV3 0_HBAD_DSIM_ST3W0_V18.BIN
project-id: HBA04BV30_HBAD_DSIM_ST3W0_V18, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect standard location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
detecting firmware version...
firmware version: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.HBA04BV3 0_HBAD_DSIM_ST3W
detecting firmware build...
firmware build: BA04BV30_HBAD_DSIM_ST3W0_V18GOLDDRAGON25_GEMINI_HW 2010-03-1520-56
detecting product-id...
done
detecting languages...
language parameters detected
detected languages: En Ru Fr Es Id Tr Hi Urdu Farsi Pt Ar
Finished, time used: 5 min 22 sec
Remove/Install battery now !
Old 05-27-2010, 07:05   #2 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
try to formate ur handset ... complet mode...
br
Old 05-27-2010, 07:09   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
br
yeah i did this type but no use pls tell another solution
Old 05-27-2010, 07:13   #4 (permalink)
jagdish puri's Avatar
Member: 573120
Thanks Meter: 145
download flash file same version from support area if have or request file here at forum . flash it then problem ll solve .
Old 05-27-2010, 07:13   #5 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
then u need same good working fone......... if u have then read fullflash file from that write to the damge fone....... n post relust..
Old 05-27-2010, 07:23   #6 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
it does not get ther site how can download the latest file
Old 05-27-2010, 07:24   #7 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
yeah i tried but after that it is become dead
Old 05-27-2010, 07:25   #8 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
dead impossible... try once again
Old 05-27-2010, 07:26   #9 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
yes bro i tried so many time but same status
Old 05-27-2010, 09:00   #10 (permalink)
AUN_KHALIL's Avatar
Member: 821450
Sonork: khalil_lush
Thanks Meter: 269
bro frist check orignal firmware of flash files in phone ..
it will write in under lcd of phone .
flash with orignal flash files
if this is ur orignal flash files then read it from other phone or search it from support .
Old 05-27-2010, 09:30   #11 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
how to check orginal firmware because some service center tried in some file
Old 05-28-2010, 22:04   #12 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
if original version is unkown- then the only way is to try one by one each same model flash file
Old 05-29-2010, 07:32   #13 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
OH OOOO i will try this your sugestion
Old 05-29-2010, 07:36   #14 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
it does not get on infinity support site what do do next sir
Old 05-30-2010, 10:11   #15 (permalink)
Member: 148515
hello!
just make search for "T33+" on our support site and try one by one all files.
also, one more good advice is to disassemble phone and search for software stamp on PCB. Ussually factory mark their PCB's with short Version code.
here is example how on our forum member repairied his phone exactly by this method:
help me please mobile chine - GSM-Forum
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
All Locks open!!! dESiRE! Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-12-2011 20:19
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:31
new irc chat chanell open... #gsmhacking, #nokia_last VirtualM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 01-18-2000 15:55
Page generated in 0.27426 seconds with 9 queries
