Old 06-30-2011, 06:46   #1 (permalink)
Member: 992698
Thanks Meter: 4
Gfive N79i
please help me
format ok but no power on
COM3 [VCP0] selected
module v3.31
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:5803:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:18A59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 43 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 06-30-2011, 07:05   #2 (permalink)
Member: 992698
Thanks Meter: 4
sir please help me..................................
Old 06-30-2011, 15:06   #3 (permalink)
ORANGE MOB's Avatar
Member: 1549240
Thanks Meter: 1,130
bro your phone eeprom is damage -look!
- damaged firmware
so only way found same working phone and read from full flash and write this dead phone
The Following User Says Thank You to ORANGE MOB For This Useful Post:
Old 06-30-2011, 21:46   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you must find original software version
now, when firmware is erased there is only one way to do this:
http://forum.gsmhosting.com/vbb/show....php?t=1166957
need a flash file tv n79i urgently FullFlashPak Infinity-Box 5 11-21-2011 19:48
gfive u808 pinout khurram_player Chinese Models & Cloned Phones 13 11-09-2010 04:49
n79i phonelock DEAD FullFLASHgSMPH Infinity-Box 1 03-19-2009 12:05
I cant play games in my n79i lil_pooch-357 Chinese Models & Cloned Phones 0 02-27-2009 06:44
N79i Pinout ?? ~mr_Ten$ion~ Infinity-Box 1 11-01-2007 00:30
Page generated in 0.15830 seconds with 9 queries
