Old 01-03-2010, 15:52   #1 (permalink)
shahabuddin's Avatar
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
G'five phone lock code problem
HELLO EVERY BODY I M FACING PROBLEM OF G'FIVE U808 PHONE LOCK CODE. I TRY TO READ CODE, STANDER,STANDER FAST, SMART FAST BUT STILL SAME, HERE IS SOME LOGS
==== log: [12/4/2009 8:08:40 AM] ====
COM7 [VCP0] selected
module v3.02
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:F3CE:48F8
status: FF
Connecting at 19200, wait...
warning: wrong packet cs
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 38 sec
Remove/Install battery now !
=== log: [12/4/2009 8:09:33 AM] ====
module v3.02
Device: Autodetect 6205-6227 NOR
Action: "user code"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info protocol ver: 04
ver. sw 1: A310_PCB01_GPRS_MT6226_S01.SW_V00_02_JIEERWANG.BIN
ver. sw 2: A310.SW.V00.02.JIEERWANG, 00000000
code offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
detect standard ffs/eeprom location pass #1...
detect extended ffs/eeprom location pass #1...
detect standard ffs/eeprom offset pass #1...
ffs/eeprom record offset detected
detect standard ffs/eeprom data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: A310_PCB01_GPRS_MT6226_S01.SW_V00_02_JIEERWANG__ff s...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\A310_PCB01_GPRS_M T6226_S01.SW_V00_02_JIEERWANG__ffs_20091204-081612.B0E.bin
Backup required data Done
====> Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: eeprom
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 517 sec
Old 01-03-2010, 16:19   #2 (permalink)
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
g'five done now tnxxx to infinity team
MODERATOR CLOSE THE THREAD PLZ
Old 08-14-2011, 05:46   #3 (permalink)
Member: 1588953
is there is any master coad to reset gfive phones plz help
China Phone Lock Code Problem zahidnawaz Infinity-Box 11 06-11-2009 20:32
K330 Phone Lock code problem- PASSIONATE_BOYS Infinity-Box 5 05-26-2009 16:02
MyPhone T22 phone lock code problem lezwire Chinese Cocktail 1 01-03-2008 06:12
w810i phone lock code problem gaspardiana Sony Ericsson 7 12-19-2007 17:01
T68i PHONE LOCK CODE PROBLEM PLEASE HELP axilleask Sony Ericsson 0 12-21-2004 15:51
Page generated in 0.34227 seconds with 8 queries
