Old 06-23-2011, 05:27   #1 (permalink)
Registered User
Member: 1420255
Thanks Meter: 61
gfive u 909 flash problem
please help me how to find Gfive u909 MT6223CA CPU flash file.
Old 06-23-2011, 05:29   #2 (permalink)
Member: 1588766
Sonork: 100.1603756
Thanks Meter: 37
whats ur phone status?
ur flashfile size?
Old 06-23-2011, 05:42   #3 (permalink)
Registered User
Member: 1420255
Thanks Meter: 61
when i check read detailed info-
OM4 [VCP0] selected
module v3.95
Device: _Autodetect MT6205-6239 NOR
Checking data, wait...
Action: read/check information
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:B548:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:FFFFFF00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
flash: 00000000000000:00000000000000
number of flash chip/regions detected: 02/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\InfinityBox\MModule\operation.log
2. C:\InfinityBox\MModule\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
aborted by user
operation aborted
Finished, time used: 31 sec
Remove/Install battery now !
Old 06-23-2011, 05:44   #4 (permalink)
Registered User
Member: 1420255
Thanks Meter: 61
please help me is it flash problem otherwise my set flashchip damaged tell me .
Old 06-23-2011, 05:50   #5 (permalink)
abidottupara35's Avatar
Member: 1178222
Sonork: 100.1602620
Thanks Meter: 467
u909 flash file
Old 06-24-2011, 20:25   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
best way is to check software version printed on PCB:
here
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.16491 seconds with 9 queries
