02-21-2010, 09:19 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Gfive U800 after flash blue secreen dear all i have G`five U800 i have flash this phone but after flash phone LCD is Blue all key Pad & all function are in working but display is blue i read flash file from other good one phone but still same phone LCD is ok 1000% & working perfect on other one. so tel me what i do. here is log with i flash this phone Code: COM3 [VCP1] selected module v3.07 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware MTK25_GEMINI_PCB01_GPRS_MT6225_S00.U800_11G_B-CAM_305_20091127__fullflash_20100220-233800.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs MTK25_GEMINI_PCB01_GPRS_MT6225_S00.U800_11G_B-CAM_305_20091127__ffs_20100221-001148.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0A0F:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC257E25082501:FFFFFF00000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25082501:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 11 min 33 sec Remove/Install battery now ! |
02-21-2010, 11:33 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! is this first flashing log? there is missing orignal firmware version. maybe you can check your operation Log file for earlier operations? maybe there we can find Original software version? |
02-21-2010, 11:48 | #3 (permalink) | |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
Code: New firmware detected (v.3.07, database date: 16.01.2010): V840_GEMINI_PCB01_GPRS_MT6225_S00.V940_V02.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== ====> Backup required data ... reading: V840_GEMINI_PCB01_GPRS_MT6225_S00.V940_V02__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\V840_GEMINI_PCB01_GPRS_MT6225_S00.V940_V02__ffs_20100220-043435.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done ! | |
02-24-2010, 08:27 | #6 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | sir i flash with different version these found in new phones & not available on support area for example on this one phone on but LCD blue like in computer vga driver problem MTK25_GEMINI_PCB01_GPRS_MT6225_S00.U800_11G_B-CAM_305_20091127__fullflash_20100220-233800.B0M & same on this one MTK25_GEMINI_PCB01_GPRS_MT6225_S00.U800_12G-2_G-CAM2_317_20100114__fullflash_20100223-234814.B0M |
02-26-2010, 11:10 | #7 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
this means that your hardware is different and firmware is not suitable for phone. Keep search for correct one | |
03-05-2010, 14:14 | #8 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | i found File & my phone is working good on this file but camera module not ready here is link i upload two new version for better support V840_GEMINI_PCB01_GPRS_MT6225_S00.V940_V02.BIN MTK25_GEMINI_PCB01_GPRS_MT6225_S00.U800_12G-2_G-CAM2_317_20100114__fullflash_20100223-234814.B0M http://www.4shared.com/file/23481531...3/Desktop.html |
The Following User Says Thank You to Hafiz ArslanAli For This Useful Post: |
PLS HELP U800 after FLASH Blue screen | bedear | UST Pro II | 1 | 05-10-2009 13:29 |
t630 after flash blue screen | faizan15 | Sony Ericsson | 9 | 11-24-2007 09:47 |
$$ how to repair sendo 620 after flash blue display$$ | rajabrotherscom | Multi-Box | 6 | 01-13-2007 13:20 |
After flashing Blue-tooth not work on 6310 | roniri | Nokia Digital Core Technology 4 ( DCT-4 ) | 19 | 02-01-2003 18:48 |
